? Maintenance Required Light
Old Apr 18, 2005 | 06:00 PM
jdmgsr_ej1's Avatar
Default ? Maintenance Required Light
2000 Integra Gs-r
I wanted to know what are the usual reason that the maintenance required light usually comes on. Some people have told me that it just means you need an oil change but i just wanted to ask because i am not sure if they are right and i am not sure myself because my car is running just fine.
Old Apr 18, 2005 | 06:01 PM
njandrewg's Avatar
Default Re: ? Maintenance Required Light (jdmgsr_eg6)
just means u need maintance
Old Apr 18, 2005 | 06:04 PM
jdmgsr_ej1's Avatar
Default Re: ? Maintenance Required Light (njandrewg)
i figured that much but what kinda maintence might it be, i would think if it is something serious then the check engine light would come on but its not.
Old Apr 18, 2005 | 06:07 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
search for "maintence light" but in recent, and archives. its been asked, and covered plenty of times, and im sure its prolly in the FAQ's.
the "maintenence light" is a reminder at i belive 7500 miles to change your oil. under the steering coloum to the right of the dash is a small box, with a blue button, you put the key on, engine off.. and hold it 3 seconds and it will reset for another 7500 miles.
Old Apr 18, 2005 | 06:16 PM
jdmgsr_ej1's Avatar
Default Re: ? Maintenance Required Light (Built B16A)
yea i already reset it and everything but i just wanted to know what it meant when it came on. but i dont know y it would come on because i change my oil every 2000-2500 miles.
Old Apr 18, 2005 | 06:44 PM
eag36's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmgsr_eg6 &raquo;</TD></TR><TR><TD CLASS="quote">yea i already reset it and everything but i just wanted to know what it meant when it came on. but i dont know y it would come on because i change my oil every 2000-2500 miles. </TD></TR></TABLE>
It's like built said, it's only a reminder light. It's runs off the odometer. It goes off every 7500 miles. It has no possible way of knowing how often you change your oil or what condition it is in. So everythime it goes off, you've got another 7500 miles.
Old Apr 18, 2005 | 07:09 PM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmgsr_eg6 &raquo;</TD></TR><TR><TD CLASS="quote">i change my oil every 2000-2500 miles. </TD></TR></TABLE>
then i would suggest every time you do change your oil.. to key on, engine off.. and reset that button, and your clock will start from there...
Old Apr 18, 2005 | 08:41 PM
Samosagison's Avatar
https://honda-tech.com/zerothread?id=1214585
[QUOTE=Built B16A]search for "maintence light" but in recent, and archives. its been asked, and covered plenty of times, and im sure its prolly in the FAQ's.
QUOTE]
Agreed but i'll help you a little bit
Old Apr 18, 2005 | 08:47 PM
neo1z's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">just means u need maintance</TD></TR></TABLE>
That isnt true. Dont spread what you dont know.
It just counts mileage, thats all it is. You could have done maintenence at 6500 miles, and it will still come on at 7500. Search.
ChangT
Oct 3, 2012 09:32 PM
Hektik Photography
Oct 1, 2009 07:34 PM
B18CR-X
Nov 11, 2003 06:04 AM
redteg1
Oct 14, 2002 04:40 AM
RuskeR
Jul 6, 2002 04:12 PM
