tranny stumped
Old Apr 18, 2005 | 03:58 PM
tallguy's Avatar
Default tranny stumped
Help me..... My Friends man hood has left the garage because we cant get it to go back together.
Old Apr 18, 2005 | 04:03 PM
simon98h22's Avatar
Default Re: tranny stumped (tallguy)
*Edit*
Old Apr 18, 2005 | 04:09 PM
tallguy's Avatar
Does anyone know what would cause the trans case not to fit correctly. we nver pulled the gears out so i know there in all the way. the only thing i can think of is the bearings not seating correctly.
Dan GSR's Avatar
Default Re: tranny stumped (simon98h22)
place transmission on two 2x4's so its not resting on the mainshaft
spread the C clip, while tightenin down 4 bolts...one on each corner
Old Apr 18, 2005 | 04:24 PM
tallguy's Avatar
Ok put it two 2x4's and it sits the same way.
Old Apr 18, 2005 | 04:26 PM
tallguy's Avatar
the case doesn't sit low enough for the c clip to be cousing the problem.
Old Apr 18, 2005 | 04:55 PM
mr. carpenter's Avatar
Default Re: (tallguy)
it's a real bitch to get back on. i ended up using needle nose pliers instead of the ring clip ones.
Old Apr 18, 2005 | 05:02 PM
Dan GSR's Avatar
then part #3 is probably not lining up with the hole on the gear side case
got to get that part to line up, try putting it in a different gear
Old Apr 18, 2005 | 05:08 PM
DA-nteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallguy &raquo;</TD></TR><TR><TD CLASS="quote"> the only thing i can think of is the bearings not seating correctly.</TD></TR></TABLE>
my guess ..
Old Apr 18, 2005 | 07:05 PM
Weston's Avatar
You have to mess with the shift selector to get the case to fit back on. Also make sure that the tab on top of the mainshaft is lined up correctly with the case. Once the case is on and bolted down, you'll need to get that snap ring back in place... you can usually just turn the tranny upside down and the countershaft will slide up and the ring will snap onto it and hold it.
Old Apr 19, 2005 | 07:50 AM
boomslang's Avatar
Default Re: (Weston)
The C clip is causing your problem. Expand it and the casing will slide down.
Old Apr 19, 2005 | 10:56 AM
95lstegman's Avatar
Default Re: (boomslang)
i'd say something, but both issues have been covered. take the top half off and make sure the rod in the shift mechanism is all the way into the hole beneath, and make sure you do like somebody said and tighten a few bolts down while having a friend expand the C-clip. unless you're somewhat talented, you'll need a friend.
wittynamessuck
Honda Civic (2001 - 2005)
Aug 1, 2011 10:33 AM
ewendc2r
Transmission & Drivetrain
Jun 10, 2010 09:36 PM
RobEK
Jun 3, 2009 08:21 AM
1 2 NV
Jan 28, 2008 07:13 PM
boomslang
Oct 29, 2001 02:27 PM
