Idling problem
Old Apr 18, 2005 | 08:12 PM
UNKNOWN_MEMBER's Avatar
Default Idling problem
Everything use to be cool untill 1 morning I started my car and it didn't want to idle. I would have to give it gas for literally 2minutes or so. If I was to let it go it would just die. When the motor is warm and i'm driving and get out of gear or push the clutch in it will idle at 1500 untill I come to a stop then just idle real low like 500-600 rpm, sometimes it'll die. What can cause this problem? Already cleaned the IACV still does it.
Old Apr 18, 2005 | 11:43 PM
gsr-2nr's Avatar
Default Re: Idling problem (UNKNOWN_MEMBER)
ur iac might need to be replaced, adjust ur idle also
Old Apr 19, 2005 | 06:49 AM
Default Re: Idling problem (gsr-2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr &raquo;</TD></TR><TR><TD CLASS="quote">ur iac might need to be replaced, adjust ur idle also </TD></TR></TABLE> I tried a different iacv too! still the same thing. Everytime I adjust the idle, I would have to adjust it like every week, it's like just a temprorary fix only. And the bad thing about that is when I raise the idle more, when getting out of gear and just strolling coming to a stop the idle would raise higher than 1500rpm and then drop back down to probably around 800-950.
Old Apr 19, 2005 | 07:48 PM
bump
Old Apr 20, 2005 | 12:39 AM
Manifold i'm using doesn't have FITV also.
lude98SH
Dec 16, 2005 01:37 PM
quik2kSi
Dec 27, 2003 09:04 AM
raene
Nov 7, 2002 08:21 PM
