B20... what to do.
Old Jul 16, 2005 | 09:00 PM
SiRk's Avatar
Default B20... what to do.
anyone have any suggestions for my b20?? I was thinking that I should just build it up and make it one badass b20...others want me to turbo it.. ehh... nitrous... no.... any other suggestions? thanks.!
Old Jul 16, 2005 | 09:07 PM
thaiphob's Avatar
Nikon!!!
Default Re: B20... what to do. (SiRk)
If you dont want to go FI...all you got left is NA so build up the b20 or do a crVTEC.
Old Jul 16, 2005 | 09:33 PM
JDMIntegraIE's Avatar
Default Re: B20... what to do. (thaiphob)
Old Jul 17, 2005 | 05:40 AM
IntegraGSR(-1)'s Avatar
ok...basiclly you can do all motor CRVTEC set up..just get you a vtec head..the stock bottom end can take all motor pretty good.if you want to run turbo keep in mind that the bore on the B20 is 84mm so the piston walls are already thin, alot of peolpe start running boost on factory B20 and POOF!...if you wanna do very much boost at all youll really need to get the block sleeved which will run you aorund 1000$ but its the only way youll know that it will handle it. and i sure someone will get on here and say "oh ive ran 14psi on a factory B20 and it did fine," but fact of the matter is that your only suppose to run 10psi MAX on a gsr or type r factory bottom so how could you run it on a nonvtec B20 block. just take your time and set a goal and do it..if you wanna do boost, sleeve the block and have at it..if you wanna do all motor thats fine too if youve ever seen a dyno sheet of a B20 VTEC all motor the torque curves spikes fasts and holds thoughout rpm range as a boost car does not..well up to you good luck with whatever you do
Old Jul 17, 2005 | 07:21 AM
Boosted Power's Avatar
If you want the most out of torque......go turbo.
Old Jul 17, 2005 | 07:36 AM
TurBoTeG's Avatar
turbo
Old Jul 19, 2005 | 01:40 AM
SiRk's Avatar
allright... thanks for the suggestions...I think all motor seems like the best choice... but.. I'll keep turbo in mind if I find some money... what cams are good for aB20??? any other suggestions on parts??
Old Jul 19, 2005 | 10:31 PM
Dc4turbo408's Avatar
Default Re: (SiRk)
ummm.. b20 turbo?? not a good idea... b20 is best of b20 vtec...
since ur gonna do a all motor.. your gonna need a b16 head, very aggressive, with that head u should get some skunk2 cams.... u will feel he power of vtec..
but motor does cost a lot of money so good luck..
I boost all day long.. better, and cheaper..
Old Jul 21, 2005 | 09:40 PM
SiRk's Avatar
I have the b20 and a b16 head already... so buying a motor isn't the problem...I really want to do the b20 vtec... are what do I need... to buy or to have done to my b20 so that I can put the b16 head on it??
Old Jul 21, 2005 | 10:00 PM
DAmn's Avatar
Default Re: (SiRk)
buy a b16 tranny to go with it
X2BOARD
Aug 20, 2014 10:09 PM
mysterysktr7
Apr 23, 2009 07:51 PM
prjctwhteg
Oct 21, 2006 01:53 PM
l3owen
Feb 7, 2004 11:13 AM
