running to lean setting engine light
my car is running way to lean and setting my check engine light. i was woundering
since my distrubituter cap is pretty much fried if that would cause the problem.
i have a fireball ingition system on the car. i was wo8ndering what and where i could get a good cap for my distruituer or does it make a difference
thanks
thanks
I'm going to assume you have a turbocharged LS. If so, have you ever had the AFR tuned.
Start off by finding out if your fuel pressure is within spec.
Possible causes of "system to lean":
Fuel pump insufficient flow/pressure
Fuel feed line clogged, leaking
Fuel pressure regulator stuck open
Fuel filter clogged
Fuel injector clogged
Gasoline doesn't meet Owner's manual spec
Deteriorated Primary HO2s
Valve clearance
Exhaust leak
Fuel filter clogged
Valve clearance
Exhaust leak
cyrix12
32
Oct 24, 2006 07:42 AM
weirdone86
Sep 14, 2006 07:35 AM
