blower not working
Old Jul 14, 2005 | 10:37 PM
bretx0r's Avatar
Default blower not working
i just picked up a 1990 integra LS and when i turn the **** for the blower i dont get any air at all, it does nothing... is it a fuse/short? or is the motor going out??
thanks
Old Jul 15, 2005 | 11:03 AM
bretx0r's Avatar
Default Re: blower not working (bretx0r)
durldurldurl
Old Jul 15, 2005 | 12:43 PM
jBj's Avatar
jBj
There may be relay for the fan that needs replacing. but its a '90 so that blower motor may just be dead. Same happened to my '91 accord.
Old Aug 12, 2005 | 01:21 PM
beedoublejay's Avatar
My blower went out in my 1990 Teg and had to take the dash apart on the pass side to change it. It was pain in the ***.
Old Aug 12, 2005 | 03:21 PM
KevinCruz's Avatar
check fuses. if fuses are good check that you are getting power to blower motor. if you are getting power to blower motor connector then its probably the blower motor. to confirm you can use a jump box or battery and give the blower motor power and ground. obviously if it doesnt work when applying battery voltage to blower motor then its a bad blower motor. but u just make shure you are getting power to blower motor.
The Seller
Jan 28, 2014 05:25 PM
IHEARTMYHONDA91
Feb 14, 2010 05:40 PM
rpm1892
Honda Civic (2001 - 2005)
Jul 7, 2008 06:00 PM
bodiez
May 13, 2008 07:27 PM
LATINOSPEED
Aug 1, 2007 09:06 AM
