Fuel Pump Question...
Ok where can I get an after market fuel pump? that I can use with my stock 98 LS only modification is intake....I've looked for pumps cheapest I could find is $170 so trying to go with an after market one...one more thing I hear a slight ticking when car is in idle coming from the driver side...is there a chance that might be my timing belt? all feedback welcome..thanks...
What are you trying to accomplish with the aftermarket fuel pump? Are you looking at 255 lph pumps? Are you planning on running Forced Induction? If you are just going to keep with light mods, the stock one will do you fine for now. Take that money and buy cams, or a good clutch, something you will enjoy much more.
Not sure if anyone could vouch for this since I dont have naturaly aspirated, but you could prob get some good power out of light mods, maybe some 270 or 310cc injectors, and do the fuel pump later if you feel like going further..
well to be honest the only reason I need a fuel pump is because I'm suspecting problems with mine...feels like my car almost dies out in 4th or 5th gear on highways...so I'm just looking for an aftermarket fuel pump that is fine for my stock LS....and that is reasonable in price by reasonable I mean $70-$140....
don't swap out your fuel pump as a performance upgrade if all you have in it is an intake.
if your fuel pump if bad, thengo with an aftermarket pump, but not a high capacity one.
Try a 190lph walbro for $79 (there is a HT sponsor that sells fuel pumps in the sponsor section).
here you go:
https://honda-tech.com/zerothread?id=298292
also, i was looking at the holley fuel pump that jeggs sells for our tegs as well.
Modified by Cliffjumper2 at 10:40 PM 7/22/2005
here you go:
