State ref smog
Old Jul 25, 2005 | 12:51 PM
UNKNOWN_MEMBER's Avatar
Default State ref smog
ok long story short, trying to get motor bared. went today and passed smog but failed visual. guy said when i go back he has to do everything again, only thing is for smog, on HC the max was 121 and what i got was 121. I was thinking if i go again it might be higher? . so what can i do to bring my HC down a bit? My timing as at 15btdc. also i think high HC means running rich? and that can be because of my 255walbro. so yea....
Old Jul 25, 2005 | 01:11 PM
Spec R's Avatar
Default Re: State ref smog (UNKNOWN_MEMBER)
changing oil surprisingly brings down the HC's, assuming nothing else is wrong.
Old Jul 25, 2005 | 01:49 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">ok long story short, trying to get motor bared. went today and passed smog but failed visual. guy said when i go back he has to do everything again, only thing is for smog, on HC the max was 121 and what i got was 121. I was thinking if i go again it might be higher? . so what can i do to bring my HC down a bit? My timing as at 15btdc. also i think high HC means running rich? and that can be because of my 255walbro. so yea....</TD></TR></TABLE>
why did you fail visual? what did he say you had in there that caused it to fail
Old Jul 25, 2005 | 02:07 PM
Default Re: State ref smog (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">
why did you fail visual? what did he say you had in there that caused it to fail</TD></TR></TABLE> well they were being dicks i guess cause everything was going fine. he even told me that they're going to get me for something, they're just looking for it. so he wrote me down for the pipes behind the intake manifold. the motor oil is already fresh.
Modified by UNKNOWN_MEMBER at 3:18 PM 7/25/2005
Old Jul 25, 2005 | 02:47 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote"> well they were being dicks i guess cause everything was going fine. he even told me that they're going to get me for something, they're just looking for it. so he wrote me down for the pipes behind the intake manifold. the motor oil is already fresh.
Modified by UNKNOWN_MEMBER at 3:18 PM 7/25/2005</TD></TR></TABLE>
well from the looks of that pic your EGR system is modified, judging by your avitar i am gonna guess that you have a DA? is it an automatic? your fuel cap failed visual, i dont know how the hell it did that because i have never seen that and it appears that you have improperly routed vacuume lines. Depending on which lines were ran where that could be the culprit for the max measured HC. I briefly looked at your page with your car on it, how about listing your mods for us that you had on the car when you took it to the ref
Old Jul 25, 2005 | 03:09 PM
well from the looks of that pic your EGR system is modified, judging by your avitar i am gonna guess that you have a DA? is it an automatic? your fuel cap failed visual, i dont know how the hell it did that because i have never seen that and it appears that you have improperly routed vacuume lines. Depending on which lines were ran where that could be the culprit for the max measured HC. I briefly looked at your page with your car on it, how about listing your mods for us that you had on the car when you took it to the ref</TD></TR></TABLE> the car is a stock b17 now with just a exhaust. You are looking at the wrong side, look right to where it says modified, it's the vacuum lines, wiring to sensors, and fuel injection. It was because i had the fpr valve connected when i wasn't supposed to. Could that be the reason why? Having the fpr connected to the fpr valve then back to the intake manifold? and yes the car is a DA and WAS heavily modified .
Old Jul 25, 2005 | 03:11 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote"> the car is a stock b17 now with just a exhaust. You are looking at the wrong side, look right to where it says modified, it's the vacuum lines, wiring to sensors, and fuel injection. It was because i had the fpr valve connected when i wasn't supposed to. Could that be the reason why? Having the fpr connected to the fpr valve then back to the intake manifold? and yes the car is a DA and WAS heavily modified .</TD></TR></TABLE>
it certainly could be, that could be causing you to get that 121 on your HC, as far as i am aware the 92 GSR doesnt have an EGR system (last time i looked under my hood i didnt see one) so i dont get why they tagged you for that too
Old Jul 25, 2005 | 06:33 PM
no no you are looking at the wrong side. look right of it, not left. wish me luck tomarrow.
Old Jul 25, 2005 | 08:09 PM
so can anyone tell me why my HC is high?
Old Jul 26, 2005 | 07:25 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">no no you are looking at the wrong side. look right of it, not left. wish me luck tomarrow.</TD></TR></TABLE>
DIU you got tagged for MODIFIED EGR FUNCTIONAL AND SPARK CONTROLS (either that or fuel cap, since you took the pic at an angle its hard to see) i SEE the **** on both sides my friend but if you fix one that doesnt make the other 2 magically go away
Old Jul 26, 2005 | 07:26 AM
temp's Avatar
Default Re: (UNKNOWN_MEMBER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">so can anyone tell me why my HC is high?</TD></TR></TABLE>
your HC isnt high considering i have had mine over 600ppm b4, could be a number of things but typically high HC (a lot higher then yours) implicates some sort of failing cat or richness
Old Jul 26, 2005 | 08:39 AM
Default Re: (temp)
my friend my friend, you gave 2 wrong answers. I passed today by hooking up the rail on the back of the intake manifold, retard timing from 15 to 14, and run fresh 89octane. and no man i didn't get tagged for EGR, GSR motor didn't have an EGR, look at the left, it says N/A.
Old Jul 26, 2005 | 09:59 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">my friend my friend, you gave 2 wrong answers. I passed today by hooking up the rail on the back of the intake manifold, retard timing from 15 to 14, and run fresh 89octane. and no man i didn't get tagged for EGR, GSR motor didn't have an EGR, look at the left, it says N/A. </TD></TR></TABLE>
my friend you have 3 things highlighted above, those 3 things are things that need fixing/readding, etc.......again the angle that you held the sheet at is pretty bad but those 2 additional things could have affected it.....but congrats on passing :-D
Old Jul 29, 2005 | 09:20 AM
Default Re: (temp)
my friend you have 3 things highlighted above, those 3 things are things that need fixing/readding, etc.......again the angle that you held the sheet at is pretty bad but those 2 additional things could have affected it.....but congrats on passing :-D</TD></TR></TABLE> yea i know but i guess the thing i had wrong was affliated with all three thigns. And man does it feel good to be legal.
Old Jul 29, 2005 | 10:45 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote"> yea i know but i guess the thing i had wrong was affliated with all three thigns. And man does it feel good to be legal.</TD></TR></TABLE>
i know that feeling, **** once my swap in my CRX was reffed i was very happy
boxeocampeon
Engine Management and Tuning
Aug 24, 2009 03:13 PM
mike03,95civic
Aug 17, 2007 05:38 PM
ZXRider
Jul 10, 2007 01:56 PM
-Championship-
Sep 8, 2006 09:27 PM
smelldaOdaa
Mar 25, 2006 04:24 PM
