Need help!
Old Jul 22, 2005 | 10:15 PM
halozero's Avatar
Default Need help!
Recently in car accident.
Front bumper got crushed, pushed the hood up and cracked it.
I bought a new bumper and new hood, went to swap, then realized that this metal thing was pushed 6 or so inches back towards then engine, making it impossible for me to get the bumper on or close the hood.
I am unsure of what this part is called.
What's it's name? What does it cost to replace? Where can i get a replacement? Is it a simple bolt on swap or will it require bodyshop work?
thanks in advance.
Old Jul 22, 2005 | 10:23 PM
DynastyRacer22's Avatar
Default Re: Need help! (halozero)
its a core support or a radiator support..
Old Jul 22, 2005 | 10:25 PM
gsrious's Avatar
if you don't know how to weld then i'd suggest you going to the shop to get it done.
if the impact pushed your rad. support back that far... you should also inspect the frame itself for any damamge.
Old Jul 22, 2005 | 10:40 PM
halozero's Avatar
Default Re: (gsrious)
frames fine, it was the back of a truck, the toe hitch pushed form the emblem up back, basically it bent around the frame... car runs fine just leaking coolant... but can't really dive into it until i can take off my hood and bumper and inspect it, but i need it to get around currently.
Old Jul 23, 2005 | 12:43 AM
apok's Avatar
Default Re: (halozero)
To lower labor costs, remove all the stuff yourself. To remove the core support, you'll just need to find and drill two welds. Shouldn't be too hard even for a beginner.
g075m0k3d
Paint and Body
12
Nov 9, 2011 03:06 PM
sde780
Apr 30, 2008 04:35 PM
Jman8108
Paint and Body
May 23, 2007 09:31 AM
ERIC!
Apr 5, 2006 06:37 AM
vxnine
Oct 18, 2004 10:23 PM
