to drain fuel??
Old Jul 23, 2005 | 06:49 PM
kaj's Avatar
kaj
Default to drain fuel??
i'm assuming i drain fuel from the spot on the front of the gas tank? i see what looks like a rubber cap about 3-4" in diameter. is this where i need to drain it from? i'm assuming there is a plug underneath? anyone know what size it is?
also, what keeps me from putting a petcock here so i can drain fuel and add race gas as needed?
thanks.
oh, and i did run a search and only came up with questions about draining fuel out of a crx. if this is the same, please disregard the first part of this post. thanks!
Old Jul 23, 2005 | 06:58 PM
EMJAY's Avatar
why are you draining? .... you want to put in higher octane?
Old Jul 23, 2005 | 07:51 PM
kaj's Avatar
kaj
Default Re: (kb12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb12 &raquo;</TD></TR><TR><TD CLASS="quote">why are you draining? .... you want to put in higher octane?</TD></TR></TABLE>
for my tune, yes. i think i want to drain it all out and put in exactly 5 gallons of 104 and 2 gallons of 91.
Old Jul 24, 2005 | 06:15 AM
ALMXDUPINTEGRA's Avatar
unscrew the filter and turn on the pump
Old Jul 24, 2005 | 07:56 AM
IN VTEC's Avatar
Default Re: to drain fuel?? (kaj)
There should be a bolt on the bottom of the gas tank facinnd downward. Mine is on the driver-side rear corner.
Old Jul 24, 2005 | 11:39 AM
s2kkid's Avatar
Default Re: to drain fuel?? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">There should be a bolt on the bottom of the gas tank facinnd downward. Mine is on the driver-side rear corner.</TD></TR></TABLE>
This is kinda off this topic some, but invtec you seem to know allot about these kinds of things,
If I have my car tuned for race gas, with say a hondata, Does that mean, I must run race gas all the time? Or can I have a seperate tune for the pump gas? and if thats even possible how do you switch over?
Just a kinda newbie question with tuning
Old Jul 24, 2005 | 09:42 PM
EVOLMTR's Avatar
Default Re: to drain fuel?? (vtecluder97)
Modified by EVOLMTR at 8:09 AM 7/29/2005
Old Jul 24, 2005 | 10:52 PM
s2kkid's Avatar
Default Re: to drain fuel?? (EVOLMTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOLMTR &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1317226...
WTF!!!!!!!</TD></TR></TABLE>
BAN!
Old Jul 25, 2005 | 04:18 AM
IN VTEC's Avatar
You need separate tunes. Use two chips and ZIF socket.
Old Jul 25, 2005 | 05:26 AM
Kaj is a scammer
Old Jul 26, 2005 | 03:48 PM
kaj's Avatar
kaj
Default Re: (ALMXDUPINTEGRA)
why don't you guys go check the thread again to read both sides of the story.
cmarsh90
Jan 27, 2007 04:05 PM
GrimLude
Sep 27, 2006 09:53 AM
ef_you_again
18
Mar 25, 2005 08:25 AM
crxh22project
Jan 17, 2005 11:52 AM
