obd2 to obd1 conversion question... searched
Old Jul 22, 2005 | 01:09 PM
gsr_to_the_MAX's Avatar
Default obd2 to obd1 conversion question... searched
i have a 98 gsr w/ basic bolt ons. im throwning a cel due to no o2 in my cat b/c i put in a high flow cat. i know that the obd2 involves 2 o2 sensors in the header and cat and the obd1 only has 1 o2 sensor in the header correct?
my question: if i do a obd1 conversion, will i still throw a cel? since the obd1 only reads one o2 sensor in the header which i have.
my gas mileage is horrible and i am hoping if i do this, my gas mileage will improve.
thanks
Old Jul 22, 2005 | 01:24 PM
LSvtec03's Avatar
Default Re: obd2 to obd1 conversion question... searched (gsr_to_the_MAX)
you could go obd1. or you could buy/make an o2 simulator. i don't know much about them, but i'm sure there's some info somewhere around here.
Old Jul 22, 2005 | 01:49 PM
Default Re: obd2 to obd1 conversion question... searched (LSvtec03)
id rather go w/ an obd1 conv. for future tuning purposes. anyone else?
thanks
Old Jul 26, 2005 | 08:03 AM
bostoncal's Avatar
bump for a question that I need to know also..I will find out tonight once I get the p72 or P28 ecu.
Old Jul 26, 2005 | 08:09 AM
Lan's Avatar
Lan
Default Re: obd2 to obd1 conversion question... searched (Este_Cara)
OBD2 has two O2 sensors
1 primary in the cat
1 secondary in the cat
OBD 1 has two O2 sensors
1 primary in the header
You can get a simulator to remove the CEL
Old Jul 26, 2005 | 08:39 AM
PLAGUED_DB7's Avatar
Default Re: obd2 to obd1 conversion question... searched (Lan)
If you switch to OBDI you will not have a cel, OBDII uses the 2nd O2 in the cat and OBDI only uses the header and one in the front of the cat.
You could also just get a bung and stick that O2 in your high flow cat.
Old Jul 26, 2005 | 06:12 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">OBD2 has two O2 sensors
You can get a simulator to remove the CEL </TD></TR></TABLE>
obd1 only has one 02 sensor; in the cat for gsrs and in the header for everything else.
724chris
Jan 23, 2010 07:04 PM
stiffinEK
May 3, 2009 12:40 PM
elmalouno
Jul 18, 2004 08:55 PM
liquidxEG
May 25, 2004 06:21 PM
ajchen
Apr 3, 2003 08:24 AM
