starting problem
Old Jul 25, 2005 | 01:14 AM
iHATEspeedbumps.'s Avatar
Default starting problem
when i start my 94 ls it starts up fine but the idlin is bad. starts up then goes to 1500rpm then down to 500rpm then 1000rpm. does anyone know the problem or have had this problem before?
Old Jul 25, 2005 | 01:49 AM
kraig8's Avatar
check all your vacume lines. sounds like a vacume leak. hope this helps
Old Jul 25, 2005 | 02:35 AM
Default Re: (kraig8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kraig8 &raquo;</TD></TR><TR><TD CLASS="quote">check all your vacume lines. sounds like a vacume leak. hope this helps</TD></TR></TABLE>
any pictures on which vaccum hose to check?
Old Jul 25, 2005 | 03:47 PM
bump.
Old Jul 25, 2005 | 03:52 PM
jay_c's Avatar
Default Re: (iHATEspeedbumps.)
I had that happen to me before, turned out to be an IAC valve.
Old Jul 26, 2005 | 01:42 AM
Default Re: (jay_c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay_c &raquo;</TD></TR><TR><TD CLASS="quote">I had that happen to me before, turned out to be an IAC valve. </TD></TR></TABLE>
got a pic of the IAV, sorry for being such a noob.
Old Jul 26, 2005 | 04:09 AM
JDM-EJ1's Avatar
Have you tried adjusting your idle adjustment screw? What about trying to pull the gas pedal away from you while you're in the car.
Old Jul 26, 2005 | 04:52 AM
Duane_in_Japan's Avatar
Default Re: starting problem (iHATEspeedbumps.)
Search for my idle post in the Accord form within the last 60 days for sure. I have a list of malfunctions for you to check. Search is always your first step but I will point the way this time.
duscar
Feb 25, 2008 02:24 PM
EG9_808
Mar 2, 2007 11:23 AM
C1CRX
15
Jun 7, 2006 05:36 AM
TypeRPaul
May 21, 2004 05:43 PM
RGoose18
May 20, 2004 04:47 PM
