Lowering
Old Jul 24, 2005 | 01:39 PM
tegkev3's Avatar
Default Lowering
I was wondering what the difference is between regular springs and coilovers. Which would be better for my 98 Integra? Also, would i need new shocks or struts when i lower it? Any helpful info would be great!
Old Jul 24, 2005 | 02:43 PM
EMJAY's Avatar
whoo you are really new aint you...well first off it might have been better to search. depending on the ride height you want = springs or coilovers you buy. coilovers are adjustable, springs are not. new shocks is a must with aftermarket springs
Old Jul 24, 2005 | 05:05 PM
nxda9's Avatar
Default Re: Lowering (tegkev3)
if u want coilovers dont buy the cheap stuff,they break. even expensive ones bang around a little bit n make noise. lowering springs are nicer but u wont get as low as u probly want. and if your oem shocks are still good u can use em. no matter what id recommend a camber kit though, it'll save u a lot of cash. id go with springs.
Old Jul 24, 2005 | 06:08 PM
crackerjacker006's Avatar
Default Re: Lowering (nxda9)
if you plan on lowering it much, struts and a camber kit are almost necessary. As for coilovers vs. springs i would go with springs. You can get springs that drop your car pretty low, maybe not as much as coilovers but you must remember the lower you go the worse it is on your car. Springs also ride much better, dont rattle around and dont break like coilovers can.
Old Jul 24, 2005 | 06:47 PM
thriller's Avatar
i heard coilovers are a bumpier ride than lowering springs.
Old Jul 24, 2005 | 07:19 PM
GDR888's Avatar
Default Re: Lowering (thriller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thriller &raquo;</TD></TR><TR><TD CLASS="quote">i heard coilovers are a bumpier ride than lowering springs. </TD></TR></TABLE>
YEP! imo
Old Jul 29, 2005 | 11:08 PM
thriller's Avatar
Default Re: Lowering (GDR888)
whats imo?
Old Jul 29, 2005 | 11:14 PM
IntegraCF21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thriller &raquo;</TD></TR><TR><TD CLASS="quote">whats imo?
In My Opinion.
Old Jul 29, 2005 | 11:23 PM
redDAinteg's Avatar
Default Re: Lowering (HondaTeg6)
which would be better overall:
1. skunk2 coilover
2. omni slips coilovers
3. neuspeed springs
4. eibach springs
Old Jul 30, 2005 | 12:16 AM
Default Re: Lowering (redDAinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">which would be better overall:
1. skunk2 coilover
3. neuspeed springs
4. eibach springs</TD></TR></TABLE>
Better overall as in what? You should narrow it down to just springs or just coilovers first.
Old Jul 30, 2005 | 07:10 AM
njandrewg's Avatar
real coilovers if you want the best thing...since they are stiffer than springs
for example with 240sx, most coilovers have a 8/6 kg rating, while the stiffest spring RSR has a 3kg rating, somethingl ike that not really sure on the rsr #.
But if you just drive on the street springs are fine
Old Jul 30, 2005 | 09:36 AM
UnlimitedHonda5
Guest
Posts: n/a
Default Re: Lowering (njandrewg)
you can buy springs, shocks, and a threaded sleave, wich is like a broken up coilover in a lot of peaces, but coilovers are used to corner weight a car not just lower, i'd go with koni yellow/eabiach springs, you can go like 2'' maybe more and its better on your car.
Old Jul 30, 2005 | 09:43 AM
phateless's Avatar
tein springs.
Monkey Z.'s Avatar
I say get Tein Basic Coilovers, they don't have adjustable dampening (gas pressure in shock) but they are about the same $ as good shocks and springs and most of us know tein makes quality
Old Jul 30, 2005 | 09:45 AM
JDM-EJ1's Avatar
Default Re: (kb12)
Coilovers are adjustable, springs aren't. Get coilovers.
Old Jul 30, 2005 | 03:41 PM
ernald711's Avatar
Default Re: Lowering (carjacker006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carjacker006 &raquo;</TD></TR><TR><TD CLASS="quote">if you plan on lowering it much, struts and a camber kit are almost necessary. As for coilovers vs. springs i would go with springs. You can get springs that drop your car pretty low, maybe not as much as coilovers but you must remember the lower you go the worse it is on your car. Springs also ride much better, dont rattle around and dont break like coilovers can. </TD></TR></TABLE>
do it right and get yourself a good full coilover system. might i add that you should get some adjustable shocks also. are you dropping you car for perfomance or looks. when you drop your car you compress the srping more. you can balance out the spring rate with adjustable shocks to how u like em. more so if you wanna drop just to drop, you won't be bottoming out all the time.
Old Jul 30, 2005 | 04:54 PM
redDAinteg's Avatar
Default Re: Lowering (ernald711)
would adjustable coilover slips like the omni and skunk2 paired with illuminas or agx's be a pretty good set up ?
Old Jul 30, 2005 | 09:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">would adjustable coilover slips like the omni and skunk2 paired with illuminas or agx's be a pretty good set up ?</TD></TR></TABLE>
Yes, that should be fine. I have the Skunk2's with Koni reds, so the those with some illuminas or agx's should be even better.
JrEk9
Suspension & Brakes
19
Nov 24, 2009 02:26 PM
markers
Honda Civic (2006 - 2015)
Jan 30, 2009 07:49 PM
teggsr925
Suspension & Brakes
11
Mar 29, 2006 11:55 AM
vaspects
20
Jul 6, 2004 12:26 PM
mrcrimane
May 5, 2003 01:09 PM
