draining power steering
Old Aug 1, 2005 | 07:12 PM
Silvteg95's Avatar
Default draining power steering
I have to drain my power steering pump, simple question, how owuld i go about doing this, id look at the manual myself but i dont have one, so this ones for you guys thanks!
Old Aug 2, 2005 | 11:12 AM
Silvteg95's Avatar
Default Re: draining power steering (Silvteg95)
does anyone know?
Old Aug 2, 2005 | 12:47 PM
TunerN00b's Avatar
I believe (please verify elsewhere) that you disconnect the return hose to the pumps reservior, put the tube in a can or something else to catch the fluid, and start the car, and use the pump itself to push all the fluid out. When the return hose stops releasing fluid, turn the car off, and you're good to go. I wouldn't run it very long after its pumped the fluid out.
Are you doing this to remove the pump entirely, or just flushing the fluid?
Old Aug 2, 2005 | 12:57 PM
Silvteg95's Avatar
Default Re: draining power steering (TunerN00b)
thanks man, im doing this to flush the transmission fluid some idiot put in my car, he didn't know integras only took special honda PSF, so hopefully this will work , thanks
Old Aug 2, 2005 | 01:05 PM
Racermech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silvteg95 &raquo;</TD></TR><TR><TD CLASS="quote">thanks man, im doing this to flush the transmission fluid some idiot put in my car, he didn't know integras only took special honda PSF, so hopefully this will work , thanks</TD></TR></TABLE>
That guy must of been an idiot!!! At lease use regualr PSF for PS. Why the hell would you even put tranny fluid in the PS???
Yes disconnecting the return hose will work fine. You can access it easier from under the car. Just turn the wheel SLOW as it comes out with pretty good force.
Old Aug 2, 2005 | 03:37 PM
Silvteg95's Avatar
Default Re: draining power steering (Racermech)
im not sure if this was right or not, i dosconnected the hose on the power steering pump, it went from the resevior to the pump itself you can see them attach by just looking down on it, i turned the wheel w/ the car turned on, and a lot came out and then it stopped coming out, just not all of it, did i do the right thing here?
Old Aug 2, 2005 | 08:16 PM
Racermech's Avatar
no, hook that hose back up, go under the car and you will see two hoses right next to each other going into the rack, they are on the driver side. One is a high preasure line, it is the larger allmost solid line. You want to disconnect the other line. When this is disconnected the pump will push fluid into the rack, but with the return house off it will push the fluid out instead of back to the pump.
Old Aug 3, 2005 | 08:28 AM
Silvteg95's Avatar
I did that and got all the fluid out and put the right stiff in, and its still making that whining noise when i turn, but i havent driven it yet its still in the garage, do i need to let the fluid circulate through fully and drive a couple mikles, or is my pump prolly shot?
billyfiction
Jun 18, 2008 08:33 AM
vtec.dc2
Aug 1, 2006 08:16 AM
rac3rb0i
Mar 16, 2006 10:56 AM
Silvteg95
Aug 1, 2005 06:59 PM
-[95cxhatch]-
Apr 12, 2004 01:38 PM
