Is this an ignition problem?
Old Aug 3, 2005 | 10:40 AM
Daguy418's Avatar
Default Is this an ignition problem?
<i tried searching but couldn't find an answer>
I turn my key to start my car and there is just a click noise. The first time this happen i tried giving it a jump start and it still wouldn't start. Now it will start but if at first there is nothing but just a click i have to bang on the steering column then try again and it usually starts. Also once i get it started i hear a low motor kinda noise i never heard before. any idea? it is a 95 gsr.
Old Aug 3, 2005 | 03:19 PM
Daguy418's Avatar
Default Re: Is this an ignition problem? (Daguy418)
anyone ?
Old Aug 3, 2005 | 03:32 PM
Keno20's Avatar
give the starter motor a tap with a cresent or something. If that solves your problem then its your starter motor
Old Aug 3, 2005 | 03:41 PM
jay_c's Avatar
Definetly does sound like a starter, I doubt banging on the steering column has anything to do with the car finally starting, in regards to the noise I also doubt its related. Id say diag the no start first and go from there
Old Aug 3, 2005 | 03:53 PM
GDR888's Avatar
Cant be the batt coz you already try to jump start but did not work,main solinoid has contact coz sometimes it starts so i would have to go with the starter.
Old Aug 3, 2005 | 04:21 PM
Irish Integra's Avatar
Default Re: Is this an ignition problem? (GDR888)
Sounds very like a starter all right, but the bump on the steering colume could suggest a loose connection on the ignition barrel, just pull off the covers and have a look, maybe even wiggle the loom about a bit while you turn the key. Good luck
johnwohl
Sep 17, 2009 03:12 PM
eskerley
Apr 21, 2008 08:01 PM
austindoyle2506
Sep 16, 2007 08:58 AM
civicbro
Feb 19, 2004 02:47 AM
lilcasino
Jul 15, 2002 01:23 PM
