Header Question
Old Aug 3, 2005 | 09:36 AM
01blackgsr's Avatar
Default Header Question
Well I ordered a T1R header, and it was supposed to come in today. However, it still hasn't arrived and I gonna have to drive the car soon. Would it be possible to drive without a header? Would there be too much heat in the engine bay, and should i risk something flying up into the ports? I could put the stock one back on if I had to.
Old Aug 3, 2005 | 09:39 AM
mrdeadman's Avatar
They let me pick
Default Re: Header Question (01blackgsr)
it would be loud as dooky and stink up your car. also it would probably heat up your engine a lot faster. i wouldn't do it for very long if i did have to drive without a header.
Old Aug 3, 2005 | 09:49 AM
Backk InTheDA's Avatar
I hate everything
Default Re: Header Question (mrdeadman)
You can drive it w/o a header, like deadman said, its going to be loud as hell. Also, since there's no header on it, its going to cool a little bit differently, and isn't good for the valves, so if you have to drive it, dont drive it to long, and not hard.
Old Aug 3, 2005 | 10:12 AM
PnoyJeff's Avatar
i say just put the stock header back on..the engine bay will get super hot quick
my friend drives without an exhaust n its real loud so im thinkin without headers its just gonna pretty much be near intolerable...u might get pulled over
Old Aug 3, 2005 | 10:28 AM
xteg95's Avatar
Default Re: Header Question (PnoyJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnoyJeff &raquo;</TD></TR><TR><TD CLASS="quote">i say just put the stock header back on..the engine bay will get super hot quick
my friend drives without an exhaust n its real loud so im thinkin without headers its just gonna pretty much be near intolerable...u might get pulled over</TD></TR></TABLE>
but he just got the o2 sensor off (other post)
whyd you take the header off before the new one came in?
Old Aug 3, 2005 | 11:16 AM
rkrone's Avatar
Default Re: Header Question (xteg01)
it will be LOUD!!!!!!!!!!!!!! and you will get pulled over
Old Aug 3, 2005 | 05:29 PM
01blackgsr's Avatar
Default Re: Header Question (rkrone)
Got the header in and on before i had to go to work, so everything turned out fine.
The reason I took it off before I even had the new one is because i *usually* get orders in then morning, early afternoon, so I was expecting this one to be the same. Oh well everything worked out, and I must say that with the T1R header/exhaust, it pulls much better now
Old Aug 3, 2005 | 07:19 PM
sportyolds's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01blackgsr &raquo;</TD></TR><TR><TD CLASS="quote">Got the header in and on before i had to go to work, so everything turned out fine.
The reason I took it off before I even had the new one is because i *usually* get orders in then morning, early afternoon, so I was expecting this one to be the same. Oh well everything worked out, and I must say that with the T1R header/exhaust, it pulls much better now </TD></TR></TABLE>
When I took off the stock header. I started it up and daaamn was that loud.
I think you are #4 on my list to be fun Buffalo.
Old Aug 3, 2005 | 07:39 PM
DarkDragon's Avatar
Default Re: Header Question (sportyolds)
well runnig a car without a header is a VERY bad idea. Ya its loud but is it worth warped valves? the air is alot colder than exhaust gas especialy at the head even if its 100 degrees outside the difference in air temp can lead to very bad things. Id say just wait
Old Aug 3, 2005 | 08:46 PM
xteg95's Avatar
Default Re: Header Question (DarkDragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkDragon &raquo;</TD></TR><TR><TD CLASS="quote">well runnig a car without a header is a VERY bad idea. Ya its loud but is it worth warped valves? the air is alot colder than exhaust gas especialy at the head even if its 100 degrees outside the difference in air temp can lead to very bad things. Id say just wait</TD></TR></TABLE>
he already got the new one on
Old Aug 4, 2005 | 08:46 AM
DarkDragon's Avatar
i understand he got it on, i just wanted to relay the info to him and the others saying that it would just be loud. I wanted to make sure they understood there was a danger of running it without a header
96hatchBoy
Oct 26, 2012 09:14 AM
Jowee
Mar 3, 2005 04:58 AM
desert eagle
May 4, 2004 09:15 AM
garagespecial
Jun 22, 2002 11:24 AM
Black SVT
Aug 1, 2001 03:23 AM
