VTEC PROBLEM!! HELP
Old Jul 31, 2005 | 05:17 PM
ekhatchgirl's Avatar
Default VTEC PROBLEM!! HELP
i have an LS Vtec with hondata s200, correct oil level, correct temp., have changed VTEC silanoid (i cant spell) Vtec is suppose to kick in at 5800rpm and sometimes it kicks in at 6500/7000rpm. VTEC will kick in, then hit a flat spot and fall out, then pick right back up in VTEC and pull harder. sometimes will not even kick in at all. im really confused on whats going on, it just recently started doing this to me. im not quite sure what the problem could be, so anyone with any suggestions please let me know. thanks
Old Aug 1, 2005 | 01:46 PM
ghost turtle's Avatar
Default Re: VTEC PROBLEM!! HELP (ekhatchgirl)
try checking the cams
Old Aug 1, 2005 | 02:04 PM
rkrone's Avatar
try checking your oil level first
then check all other fluid levels (coolant, fuel) and electrical connections, fuse box, ect...
Old Aug 2, 2005 | 12:21 PM
Default Re: VTEC PROBLEM!! HELP (rkrone)
oil level is fine. all fluids have been topped off, ive swapped out the ecu and check the connections, and cleaned the wires around the VTEC sylaniod. (my spelling once again sucks) i cant seem to find what the problem would be
CivicSi95
Honda Civic (2006 - 2015)
Nov 22, 2008 11:20 AM
Fastwhip
Aug 2, 2007 03:58 PM
BlckSI
Aug 29, 2003 06:48 PM
South Bay Surfer
23
Jan 2, 2003 04:42 AM
gsrhatch530
Mar 28, 2002 01:36 PM
