lsv problems ????
Old Aug 3, 2005 | 08:13 AM
ecks_fourttwo's Avatar
Default lsv problems ????
ok, heres the deal. car starts fine...warms up, idles fine and drives smooth. then it seems like when it gets a little hot the needle on my tach starts to jump around all crazy and soon after that it just dies out on me...with my foot on the peddle and everything. my tempature guage reads normal so i dont think its over heating. after letting it sit for a bit it will start back up again but only for a little while before it does it again. when i try to start it again it turns over and seems like it wants to start but it doesnt fire up. my other problem is that i cant rev past 6500...the rev limiter is set to 10000 and i have crower stage 1's and a new valve train. it seems a little wierd to me...i know theres power past 6500 so i really want to know what could be holding it back. any help is appreciated....thanks
Old Aug 3, 2005 | 08:21 AM
Sack Master's Avatar
Default Re: lsv problems ???? (ecks_fourttwo)
First thing I would check would be the ICM(ignitor). That sounds like the problem. But your ecu has also been tampered with so that could be it also.
Old Aug 3, 2005 | 08:37 AM
Default Re: lsv problems ???? (Sack Master)
the distributor is the best guess for the dieing out problem but i dont know what could be holding me back from reving past 6500
Old Aug 3, 2005 | 08:38 AM
rkrone's Avatar
how is the rev limiter at 10k? what program/mod does this?
did this problem happen before the mod? can you reverse/take it off?
check all connections under hood?
Old Aug 3, 2005 | 08:40 AM
Default Re: lsv problems ???? (rkrone)
the rev limit was set to 10k while chip/tune the ecu......
Old Aug 3, 2005 | 11:18 AM
anyone else had/have this problem????
Old Aug 3, 2005 | 02:18 PM
crx_88_si's Avatar
ignitor.
Old Aug 4, 2005 | 06:45 AM
Default Re: (crx_88_si)
we decided to check the screen on the vtec solenoid, we fould a bunch of what looked to me like metal shavings....and we also found a distributor wire that was barely connecting to the harness. the wire looked like it was just pushed in there without a clip. so now fopefully it will run right.
Old Aug 4, 2005 | 10:46 AM
GWInquisitor14's Avatar
Default Re: (ecks_fourttwo)
what ECU and chip system are u running? Its not one of those ebay things is it?
Old Aug 5, 2005 | 06:09 AM
Default Re: (GWInquisitor14)
im running a chipped p28 (uberdata)
ok, heres the update...we got the car to run and stay running. now, vtec is set to kick in at 51k but it cuts in and out until it hits 6k-62k and then stays on from there. anyone have any ideas on what it could be????
Old Aug 5, 2005 | 08:41 AM
Ekay Jay's Avatar
Sounds like a bad connection, check the wires for the vtec selinoid and oil pressure switch.
4glude
Oct 21, 2003 08:48 AM
GsTeg90
May 6, 2003 05:02 AM
Turbo Lude SH
Aug 7, 2002 12:01 PM
B20zvtecek
Jun 22, 2002 10:46 PM
