GSR IDLE PROBLEM PLEASE HELP !
Old Aug 3, 2005 | 11:02 AM
EJK20R's Avatar
Default GSR IDLE PROBLEM PLEASE HELP !
I have a stock 97 GSR and no mods at cold start my rpm is shooting up to 2500 and going down and then at 2000-2100 it fluctuates up and down and when the car is at normal temp it's at 1100. It drives fine and a stop light is at 800 rpms which is normal hits vtec fine no check engine light I'm wondering what is the problem ...?
Old Aug 3, 2005 | 11:19 AM
WhoDoYouThink's Avatar
Default Re: GSR IDLE PROBLEM PLEASE HELP ! (EJK20R)
Check your IACV or FITV, both of these can cause the fluctuating idle problems we all hate so much. good luck
Old Aug 3, 2005 | 11:34 AM
chinaski's Avatar
Default Re: GSR IDLE PROBLEM PLEASE HELP ! (2000turbogsr)
i have the same problem too. but i was told that it could be the IAT sensor is dirty.
Old Aug 3, 2005 | 12:52 PM
EJK20R's Avatar
Default Re: GSR IDLE PROBLEM PLEASE HELP ! (GeeSeR96)
thanks for the reply anyone else ...? with same problem...?
Old Aug 4, 2005 | 10:14 AM
EJK20R's Avatar
ttt
Old Aug 4, 2005 | 10:40 AM
SoEvoL's Avatar
i had that same problem, my thermo valve was fubared, apparently it just unscrewed it self.
Old Aug 4, 2005 | 02:32 PM
EJK20R's Avatar
Default Re: GSR IDLE PROBLEM PLEASE HELP ! (JDMCrx89)
bump up for more feedback's
Old Aug 5, 2005 | 04:12 PM
EJK20R's Avatar
bump this up up and away
Old Aug 5, 2005 | 04:21 PM
ONISHIMA's Avatar
i have the same problem still... i would think that my problem might me my iacv
i cleaned my TB so i guess its my IACV(idle air control valves).. bump bump...
i still dont understand why it doing thats it was working fine before? so i bump again!!
Old Aug 5, 2005 | 07:32 PM
EJK20R's Avatar
Default Re: GSR IDLE PROBLEM PLEASE HELP ! (ONISHIMA)
up up and all the way up
Old Aug 5, 2005 | 08:19 PM
SHystrdyGSRtdy's Avatar
have you checked all of the suggested things?
Old Aug 6, 2005 | 12:55 PM
EJK20R's Avatar
Default Re: GSR IDLE PROBLEM PLEASE HELP ! (SHystrdyGSRtdy)
tututu
Old Aug 6, 2005 | 04:54 PM
fishhead's Avatar
had the same thing and after hours of searching i found this and posted it on TI FITV take it off of your TB and screw in the white plastic part and it will be fixed
ALA KAZAM!!
http://www.team-integra.net/fo...earch
Old Aug 6, 2005 | 05:09 PM
ONISHIMA's Avatar
Default Re: GSR IDLE PROBLEM PLEASE HELP ! (fishhead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishhead &raquo;</TD></TR><TR><TD CLASS="quote">had the same thing and after hours of searching i found this and posted it on TI FITV take it off of your TB and screw in the white plastic part and it will be fixed
ALA KAZAM!!
http://www.team-integra.net/fo...earch</TD></TR></TABLE>
THANX AGAIN!! A++++ hopefully ppl wont ask this down the road
Old Aug 6, 2005 | 05:11 PM
fishhead's Avatar
i do not have permission to use the IM feature yet so good luck
reply if you fix the prob and tell what yours was
andysila
Apr 4, 2006 06:46 AM
2000civicsi
10
Oct 26, 2005 04:05 PM
