Compression issue?
Old Aug 13, 2005 | 03:34 PM
awps's Avatar
Default Compression issue?
Well, I am adjusting my valves today. I just bought the car a month ago and it seems like they haven't been adjusted in a really long time (the car was noisy, plus the gaps were way loose when adjusting). So far i've done 2 cylinders, the 1 and 3. But when i was turning the crank pulley to adjust TDC there was air seeping from what it sounded like the #3 cylinder (i hadn't taken the spark plugs out). It seemed like the compression would build a little when i was turning the pulley and then it would escape. Is this a normal thing or is the air not supposed to escape? and if it isn't normal could it be the spark plugs leaking the air? or could it be something more serious? the car doesn't appear to be burning any oil and it doesn't smoke at all so i don't think it is a piston ring or anything. Anyone have any suggestions???
btw i have a 92 gs-r.
Old Aug 13, 2005 | 03:47 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Compression issue? (awps)
It is normal. The piston rings do not form a perfect seal.
Old Aug 13, 2005 | 03:53 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Compression issue? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">It is normal. The piston rings do not form a perfect seal.</TD></TR></TABLE>
Yup. Otherwise you wouldn't be able to crank it manually.
JDMkidGSR
Nov 29, 2012 06:57 AM
CRXREFIC
Dec 13, 2010 09:52 AM
dopefeen
Jul 22, 2007 06:40 AM
Chris22215
Oct 5, 2005 05:00 AM
