Replacing Lower Ball Joint
Old Aug 13, 2005 | 01:32 PM
JohnWayne's Avatar
Default Replacing Lower Ball Joint
Most ball joint threads pertain to removing the ball joint from the LCA. I want to know how to remove the lower ball joint all together.
Here's a pic i found on T-I.net. I have already removed the ball joint from the LCA and taken off the crown nut and cotter pin. I want to know how to pop the ball joint out from the rotor to replace it
If you know how to do this would it be possible for you to photoshop this pic so that I know specifically what your're talkin about. Thanks in advance.
Old Aug 13, 2005 | 02:26 PM
allstockb18c's Avatar
Default Re: Replacing Lower Ball Joint (JohnWayne)
Remove the whole hub assembly out and take it to a machine shop to have the ball joint pressed out. Also why are you taking out the ball joint for? If the ball joint is still good and the boot is ripped you can go to honda and buy a new boot, a whole alot easier and cheaper then replacing the whole ball joint.
Old Aug 13, 2005 | 03:37 PM
JohnWayne's Avatar
Default Re: Replacing Lower Ball Joint (allstockb18c)
Alright so the black boot which comes in contact w/ the LCA can be replaced? Do you just pull the boot off?
Old Aug 13, 2005 | 06:48 PM
gsrboi80's Avatar
use a ball joint removal tool. Its essentialy a C clamp with different size sleeves and cups that fit over the joint an allow you to press it out easily
Old Aug 14, 2005 | 01:17 AM
all you need to do is pry off the clip that holds the boot on
Old Jun 14, 2006 | 11:23 PM
TURBODC4TEG's Avatar
ANYMORE INFO ON THIS I NEED HELP GETTING THE BOOT OFF
Old Jun 14, 2006 | 11:34 PM
__oversea's Avatar
put ractch between arm and hub, where boot is. then step on the hub(top/ like jump on it.). it will pop right off.
Old Jun 15, 2006 | 12:59 AM
Flexin5's Avatar
i think you mean that you want to take the ball joint out of the knuckle. if you don't A) have a press that you can remove the whole knuckle and press it out or B) have the ball joint remover tool; C clap with hooks basically,
then your in for a fight with that balljoint. i took the whole knuckle off, then, with the help of 3 friends, 2 holding it to the work bench, one holding a 5-8inch peice of aluminum pipe, and me swinging like a monkey hitting the pipe with a 20lb sledge hammer is the only way of getting that sucker out and back in.
Old Jun 15, 2006 | 05:23 AM
Default Re: (Flexin5)
where can u get the lower ball joints at?
Old Jun 15, 2006 | 08:08 AM
Sam92Teg's Avatar
Default Re: (TURBODC4TEG)
More like where can't you get the lower ball joints at. Dealer, auto parts stores, ebay, online vendors, etc. etc.
Old Jun 15, 2006 | 11:08 PM
Default Re: (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">More like where can't you get the lower ball joints at. Dealer, auto parts stores, ebay, online vendors, etc. etc.</TD></TR></TABLE>
i was wondering i'll check around hopefully i can do this myself
thanks
D16SohcVtec
14
Apr 12, 2009 09:23 AM
ultraforce77
Jul 15, 2004 02:59 PM
2camsaam
21
Oct 1, 2003 07:32 PM
Flamenco-T
Aug 21, 2002 11:49 PM
97hb
Mar 9, 2002 11:31 PM
