HELP
Old Aug 15, 2005 | 08:18 AM
k20dc2's Avatar
Default HELP
HELP i installed an autometer oil pressure gauge eletric, i dunt get it im getting no oil pressure , my gauge stays below 0 , im pretty sure i wired everything up , i see the oil flowing through the nylon hose , so i know that i have oil pressure , i dunno wtf is going on , i also extended the wire on my stock sensor and now when i turn my ignition to the on position my oil light on the dash does not even come on.
Old Aug 15, 2005 | 08:28 AM
simon98h22's Avatar
Default Re: HELP (k20dc2)
Where is the sending unit mounted?
List in detailed steps exactly what you did.
Old Aug 15, 2005 | 09:06 AM
k20dc2's Avatar
Default Re: HELP (simon98h22)
the unit is mounted in the front of the car , i ran a nylon hose from the block to a T fitting with the stock sensor and sender on it
Old Aug 15, 2005 | 09:24 AM
simon98h22's Avatar
2 more:
A) So your T fitting/sending unit is just hanging off the back of your block (with your sending unit off one of the branches?) Is it braced in any way? If not, this is a potential timebomb.
B) Have you checked your electricals for proper voltage?
OGMatt
Aug 15, 2011 01:11 PM
danny_civic97
Mar 12, 2007 01:00 PM
ooredteg
Dec 28, 2005 02:11 PM
Nov 13, 2004 08:56 AM
jisecup
Nov 19, 2003 10:00 PM
