Blown Head?
Old Aug 14, 2005 | 07:41 PM
yellowdcn's Avatar
Default Blown Head?
The car over heats alot and has a hard time starting and seems its not running on full strenth. The car feels sluggish and has a hard time idleing. Radiator fluid gets used up pretty quick. Oil and coolant comming out of spark plug as well as smoke. Tried pulling out spark plug wire and it ripped in half. What do you think happened? Sorry for the bad English.
I am thinking if it is worth fixing or just getting rid if this 94 Integra Coupe
Old Aug 14, 2005 | 08:17 PM
EMJAY's Avatar
get that thing fixed man! y did you let it overheat "a lot" of times? blown head gasket and i believe your burning coolant thats the white smoke.
Old Aug 15, 2005 | 12:00 AM
yellowdcn's Avatar
Default Re: (kb12)
woops down below
Old Aug 15, 2005 | 12:01 AM
yellowdcn's Avatar
Default Re: (kb12)
its not I let it, I would put collant back in and it would over heat in like another week then I would put more collant. But on Thursday it just started totally fuking up. Does a blown head gasket cause oil and coolant comming out from the spark plug wire area and the car having such a hard time idleing?
Old Aug 15, 2005 | 12:05 AM
phateless's Avatar
dude its amazing the damn thing runs at all! get it to a mechanic asap!!
Old Aug 15, 2005 | 01:20 PM
yellowdcn's Avatar
Default Re: (phateless)
any other info?
Old Aug 15, 2005 | 01:22 PM
TXSR20DE's Avatar
Default Re: (yellowdcn)
there is no question, blown HG.... this will cause all kinds of oil and coolant leaks, check the oil dipstick for coolant in the crankcase as well, i bet you find a ton
Old Aug 15, 2005 | 01:24 PM
xteg95's Avatar
[QUOTE=yellowdcn]its not I let it, I would put collant back in and it would over heat in like another week then I would put more collant. But on Thursday it just started totally fuking up. Does a blown head gasket cause oil and coolant comming out from the spark plug wire area and the car having such a hard time idleing?[/QUOTE]
wow...blowby much?...I wouldn't drive that thing anymore. Either fix it or take it seomwhere...but at least it needs a new headgasket.
Old Aug 15, 2005 | 01:40 PM
old_school_dohcvtec's Avatar
Default Re: Blown Head? (yellowdcn)
dude get the head gasket fixed before other damages occur. check your oil right now and see if it is a milky color. if it is, its the head gasket
Old Aug 15, 2005 | 04:08 PM
yellowdcn's Avatar
Default Re: Blown Head? (old_school_dohcvtec)
okay, thx for the helps guys, time to get that suker fixed pronto
Beto760
10
Jul 22, 2011 04:50 PM
aznwash3wboi
Nov 19, 2009 05:21 PM
buddy190
Feb 7, 2009 11:14 AM
Maxime
Nov 23, 2007 08:39 PM
taimysho0
Jul 27, 2007 09:40 PM
