clutch problem....please help
Old Aug 14, 2005 | 06:20 PM
b18c198's Avatar
Default clutch problem....please help
Alright about 2 months ago I lost all pressure in my pedal so I thought I was low on fluid but was not..checked the master cylinder and noticed it was leaking so I had that replaced. Although the problem only occurs when I am driving and suddenly have to slam on my brakes, simutaneously my clutch goes straight to the floor and gets stuck. I have to pull it back up and then fight to get it back in gear. Again I have a brand new master cylinder but never replaced the slave. Anyone know what could be causing this ??? and why does it only happen when I slam on my brakes? What should I do first??? Try to change the fluid and have the lines bleed, or go ahead and have the slave cylinder replaced also??? Any suggestions are greatly appreciated. This is a 98 GSr with a stage 3 exedy and aluminum flywheel btw. ????
Ashwell33
Transmission & Drivetrain
Feb 15, 2019 11:54 AM
WillyD
Oct 1, 2011 10:04 PM
ricerEJ8
Feb 23, 2008 04:04 PM
nelsond
Mar 16, 2006 05:42 AM
aengnr1
Jun 16, 2003 12:23 PM
