header install
Old Aug 13, 2005 | 02:23 PM
ERIC!'s Avatar
Default header install
I got a stainless dc sports header coming for my LS. I need reccomendations. Should I get a new gasket? Anyone know where to find torque settings also? Thanks.
Old Aug 13, 2005 | 02:27 PM
ernald711's Avatar
Default Re: header install (elephantegra)
your old one'll work, but i recommend getting a new one. also search for the torque settings or get helms or something.... i'd give them to you but i'm at work and don't have my books.
Old Aug 13, 2005 | 02:36 PM
importdude2000's Avatar
i used a gasket that came with a differnt header
(a tad thicker than oem metal
works good
Old Aug 13, 2005 | 02:42 PM
ERIC!'s Avatar
Default Re: (importdude2000)
thanks guys. so ill get a new gasket and search for the torque settings.
Old Aug 13, 2005 | 03:21 PM
Padawan's Avatar
Darth ModerVader
Default Re: (elephantegra)
If this is the first time removing the stock manifold, the original metal gasket where the flange bolts to the head will be fine to reuse. I've reused them a number of times and never had a problem with leaking. I would, however, recommend replacing the graphite donut gasket at the bottom where the cat bolts up. This gasket is soft and wears down, and reusing it can sometimes cause sealing problems.
As for the torque values, the bolts on the head should be torqued to 23 ft. lbs. starting with the center bolt and alternating outward.
Old Aug 13, 2005 | 05:11 PM
ERIC!'s Avatar
Default Re: (Padawan)
thank you very much.
JonnySBeee...
Jan 15, 2005 10:18 AM
r0cket247
Jan 15, 2004 04:21 PM
B18CYAAA
Jul 21, 2003 02:25 PM
b16a1civichb
Nov 30, 2002 07:49 PM
vtecdc2
May 29, 2002 05:30 AM
