DA Smog help
Old Aug 12, 2005 | 04:39 AM
Bonty's Avatar
Default DA Smog help
So i'm going to have to smog my car next week and I'm worried about it not passing smog, is there anything that i can do in order to have a better chance at passing smog? This is what i have in my car:
B18a1
b16 head
Dc headers and Injen intake
2 1/4 inch piping with stock cat
car is converted to Obd1
p28 ecu and obd1 dizzy
Should I have any worries?
Old Aug 12, 2005 | 04:48 AM
intgrboy's Avatar
Default Re: DA Smog help (Bonty)
ditto here - are there any additives I can use that can help me along?
Old Aug 12, 2005 | 05:54 AM
arw321's Avatar
Default Re: DA Smog help (intgrboy)
Try adding methyl hydrate to your gas (maybe 5 oz?). A little trick to fool the tail pipe sniffers.
Old Aug 12, 2005 | 01:41 PM
Bonty's Avatar
does it actually work?
Old Aug 12, 2005 | 02:19 PM
temp's Avatar
Default Re: (Bonty)
if they know what they are doing you will fail visual horribly
Old Aug 12, 2005 | 11:05 PM
Bonty's Avatar
well, we're trying to put most of the stock parts back into the car, so hopefully it'll pass, i'm not too worried, i think it'll pass
Old Aug 12, 2005 | 11:18 PM
SYTFU Tommy.'s Avatar
Default Re: (Bonty)
i say it will never pass the damn smog in cali
Old Aug 15, 2005 | 08:36 AM
temp's Avatar
Default Re: (tngay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tngay &raquo;</TD></TR><TR><TD CLASS="quote">i say it will never pass the damn smog in cali</TD></TR></TABLE>
i agree, like i said, if they know what they are doing they will see that the VTEC wires for one are clearly not OEM, they will KNOW that the motor is modded, like i said, it will fail visual
Old Aug 15, 2005 | 10:45 AM
nickG's Avatar
**** cali....we dont do a visual inspection....
but it sounds like you should be alright w/ a cat, stock cams and compression...
but run the highest octane, ive heard that helps...but i dont know..
new plugs too???
smelldaOdaa
Mar 25, 2006 04:24 PM
PePpeRedDc5
May 4, 2005 08:01 PM
niftyEJ6
Aug 31, 2004 07:59 PM
NewBorn_EG
May 30, 2004 02:59 PM
B00ST2nR
May 20, 2002 12:26 PM
