crank sensor problem
Old Aug 12, 2005 | 11:15 AM
FROSTDC2's Avatar
Default crank sensor problem
my light is on for the crank sensor, the wires arent cut but the timing belt was changed, i changed the wires and spark plugs and its running alot better but light is still on... any ideas? is the sensor just bad or could there be something else causin this light to be on? thanx for any help
Old Aug 12, 2005 | 11:20 AM
Teggy LS's Avatar
Default Re: crank sensor problem (champ white coupe)
have you reset the computer by pulling out the 7.5 fuse from the underhood fuse panel?
try it and see if it comes back
Old Aug 12, 2005 | 11:44 AM
FROSTDC2's Avatar
Default Re: crank sensor problem (Teggy LS)
no, i dissconnected battery, checked all wires.. none r cut or anything.. how do u know if its the sensor or something else, are there tests u can conduct?
Old Aug 12, 2005 | 11:45 AM
Teggy LS's Avatar
yeah, with a helms
Old Aug 12, 2005 | 11:48 AM
FROSTDC2's Avatar
how do u get ur hands on 1 of those?
Old Aug 12, 2005 | 11:53 AM
Teggy LS's Avatar
here
or just search the internet for the pdf version
Old Aug 12, 2005 | 12:07 PM
FROSTDC2's Avatar
no1 knows a few quick little tests? by the way thanx alot teggy ls!
Old Aug 12, 2005 | 12:11 PM
Teggy LS's Avatar
heres the pdf, just searched, thats all
Old Aug 12, 2005 | 01:29 PM
FROSTDC2's Avatar
looked at it for almost an hr and i cant find the part im lookin for, o well i guess ill just blow 100 on a new sensor and cross my fingers
Old Aug 12, 2005 | 01:42 PM
LoseRPunKx182's Avatar
check ur timing, crank and pulley...it could be ur ecu too...ur throw a code 4?
Code 4 deals with Crankshaft Position Sensor Circuit Malfunction (P0335) or Crankshaft Position Sensor Range/Performance (P0336).
Possible causes for these two codes are shown as:
-Crankshaft position sensor
-Crankshaft position sensor circuit
-ECM
-Timing Belt skipped teeth
are u going into limp mode?
Old Aug 12, 2005 | 02:11 PM
FROSTDC2's Avatar
Default Re: (LoseRPunKx182)
to be exact its the crankshaft fluctuation sensor, dont know if that helps, my car idles at 750 but moves up and down sometimes, idk if that means its the timing or if it was caused by the check engine light
Old Aug 12, 2005 | 04:29 PM
Teggy LS's Avatar
Default Re: (champ white coupe)
i dont even have that sensor hooked up on my b20, ive had absolutly no problems with idling. if its idling bad, check what the helms says to check. iac, idle speed, etc....
T-Mo
May 11, 2012 05:56 PM
2000siturboR
Nov 6, 2009 03:29 PM
kaddi88
Aug 25, 2008 05:14 PM
