Rough Shifting: Is Clutch Bad?
Old 12-14-2005, 11:54 PM
98LS4dr's Avatar
Default Rough Shifting: Is Clutch Bad?
I have 145K on my 96 GSR, and shifting has been fine up until late. Now its hard to get into all the gears, is my clutch going bad or is it something else? When its in gear it drives just fine, its just rough when I shift gears.
TIA
Old 12-15-2005, 12:10 AM
MugenDC4's Avatar
Default Re: Rough Shifting: Is Clutch Bad? (98LS4dr)
Low tranny fluid?
Old 12-15-2005, 12:15 AM
suzawa94's Avatar
Default Re: Rough Shifting: Is Clutch Bad? (MugenDC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDC4 &raquo;</TD></TR><TR><TD CLASS="quote">Low tranny fluid?</TD></TR></TABLE>
it's also possible fluid is dirty.
Old 12-15-2005, 02:39 AM
Deluzional's Avatar
Default Re: Rough Shifting: Is Clutch Bad? (suzawa94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suzawa94 &raquo;</TD></TR><TR><TD CLASS="quote">it's also possible fluid is dirty.</TD></TR></TABLE>
yea when was the last time you changed the fluid? that could be the problem right there
Old 12-15-2005, 03:38 AM
M Coop's Avatar
Change the trans fluid. A lot of people I know use GM syncromesh or at least 50% honda gear oil and 50% syncromesh. It's pretty amazing stuff. One of my friends literally ran his trans dry to the point where it wouldn't go into gear and then did the 50 50 mix and it shifted fine until he wrecked it. But with 145 on the clock you can probably just get the honda gear oil and be all good.
DC5Danny
01-21-2008 08:36 AM
alcary
07-09-2007 06:24 AM
BlackLudeSR
06-21-2007 01:50 PM
BrownGSR
10-13-2003 02:01 PM
shermanyang
08-17-2003 11:05 AM
Quick Reply: Rough Shifting: Is Clutch Bad?
