compression test results
Old Dec 14, 2005 | 05:24 PM
watsvtecEK's Avatar
Default compression test results
I did a compression test today. around 205psi accross the board. not bad for a 93 ls with 156,000 miles. i think im going to do a lsvtec now.
Old Dec 14, 2005 | 05:38 PM
LSracing94's Avatar
Default Re: compression test results (D 2da A9)
you must have a very friendly compression tester, 205 is very very good...but the thing that matters most is that you held the same number across the board ..get that lsvtec underway
Old Dec 14, 2005 | 05:46 PM
watsvtecEK's Avatar
Default Re: compression test results (LSracing94)
ya, i hope i did it right. i held it at wot and took out the ecu fuse and unpluged the distributer. i cranked it untill the gauge stoped going up. is this correct?
Old Dec 14, 2005 | 06:10 PM
Mr Furball's Avatar
as long as the car does not start, you did the right thing.
Old Dec 16, 2005 | 08:29 AM
LSracing94's Avatar
Default Re: compression test results (Mr Furball)
your supposed to do 5-6 cranks..sometimes your compression tester will tell you otherwise..but most cases 5-6 cranks at wot i believe.
Old Dec 16, 2005 | 08:53 AM
Karizmah's Avatar
That's damn good considering my gsr was 240ish
Old Dec 16, 2005 | 09:23 AM
CNSK's Avatar
nice #...i got 230 across my 95 gsr with 210k miles...
Old Dec 16, 2005 | 09:25 AM
M Coop's Avatar
Default Re: compression test results (CNSK)
Hey CNSK, did you figure out why your car wouldn't start? Was it a relay?
Old Dec 16, 2005 | 09:52 AM
JDM-EJ1's Avatar
Default Re: compression test results (M Coop)
Nice numbers!!
Old Dec 16, 2005 | 10:05 AM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M Coop &raquo;</TD></TR><TR><TD CLASS="quote">Hey CNSK, did you figure out why your car wouldn't start? Was it a relay?</TD></TR></TABLE>
its actually my civic swap that i had problem.....i can crank it now but still not the same....when i move my engine harness and ecu down at the bottom of the feet, it dies. Its kinda hard cause im running a p28 w/ hondata plus the jumper and its hard to stick it at the corner becuase those car run short ecu and im running the long ecu, so i have to jam the ecu up there, that cuases me to have faulty wire i believe, but which one? that my question... Also when I crank the engine when its dead cold..my engine makes loud knocking noise, stalls as i drive and idles up and down from 200 rpm to 2500. Ive adjust the tps sensor and cable line when it was warm and got it right at 1000 rpm but when i crank it cold, the rpm is at 1-200 rpm and dies. (fustrating) Now once its warm, it idles fine and no knock....Ive checked all possible solution i think...Ever since i changed the cam seal on the driver side and took off my timing belt, **** started to screw up......i check my timing and its correct also......but yes it does run but not normal....when i redline it cel pops up...when i turn it off and crank it back...cel goes away....confused....
Old Dec 16, 2005 | 10:16 AM
M Coop's Avatar
Damn, now I understand why you're frustrated. Sounds like you're right about the wiring problem on the ECU, but as for the knocking sound, I'm kinda lost, I don't even know where to start. As for the stalling, did you put on and aftermarket intake and do away with the IAC? I'm working on my boy's Civic with GSR swap which doesn't want to start when it's cold and it's because he has an aftermarket intake. I'm determined to figure out a way to incorporate the IAC so it'll run when it's cold. Don't know if that's at all relevant but I thought I'd mention it. Good luck man, I would have ripped out all my hair by now if I were you.
Old Dec 16, 2005 | 11:09 AM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M Coop &raquo;</TD></TR><TR><TD CLASS="quote">Damn, now I understand why you're frustrated. Sounds like you're right about the wiring problem on the ECU, but as for the knocking sound, I'm kinda lost, I don't even know where to start. As for the stalling, did you put on and aftermarket intake and do away with the IAC? I'm working on my boy's Civic with GSR swap which doesn't want to start when it's cold and it's because he has an aftermarket intake. I'm determined to figure out a way to incorporate the IAC so it'll run when it's cold. Don't know if that's at all relevant but I thought I'd mention it. Good luck man, I would have ripped out all my hair by now if I were you. </TD></TR></TABLE>
problem after problem....i think im gonna sell her...but ive invested so much money into her( close to 10 g's on motor and accesories).....thinking of that makes me not want to sell her and most of my parts has less then 5k miles on....
Old Dec 16, 2005 | 11:20 AM
M Coop's Avatar
Damn, man I'm sorry, that's almost enough to make me cry. So did you get rid of your IAC? Most aftermarket intakes don't allow for one, and that would definitely cause some idling problems when it's cold. Like I said, might not be relevant but since it's cold now the IAC would be more important than during the summer months.
Old Dec 18, 2005 | 07:28 AM
LSracing94's Avatar
all you guys have really high compression test results. kinda odd
MarkCayabyab
10
Oct 29, 2013 06:18 PM
speedymon
Jan 10, 2003 08:02 AM
Hybrid Boy
Aug 28, 2002 03:09 PM
MechEng
Feb 11, 2002 06:15 PM
