Quick Question?
Old Dec 14, 2005 | 12:04 PM
DAGAME's Avatar
Default Quick Question?
I lost control of my 91 integra ls-s in the snow and hit a curb on the passenger side and curbed my gsr blades and looks like i tweaked my sub-frame. What should i do if i cant allign the wheel right? Buy another sub frame and install it or buy a integra shell and swap everything over?
Old Dec 14, 2005 | 12:09 PM
suzawa94's Avatar
Default Re: Quick Question? (DAGAME)
you wont know for sure unless you replace the obvious damaged parts and have an alignment check. i would take it to a reputable body shop. they could definately tell you how extensive the damage is.
Old Dec 14, 2005 | 12:21 PM
DAGAME's Avatar
my mechanic looked under it last night, the sub frame is damaged on the passenger side make the wheel sit at an angle so ill burning up tires pretty fast.
Old Dec 14, 2005 | 12:33 PM
suzawa94's Avatar
some body shops have that frame stretcher thingy. it pulls the frame/unibody back to shape. that reminds me similar situation happened to my friend in his Paseo. he slammed into a curb going about 35-45 mph. i forget what components were actually damaged or replaced, but he needed a camber kit (aftermarket) on just one side to compensate for the uneven camber. in fact till this day that one side is still out of spec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAGAME &raquo;</TD></TR><TR><TD CLASS="quote">my mechanic looked under it last night, the sub frame is damaged on the passenger side make the wheel sit at an angle so ill burning up tires pretty fast.</TD></TR></TABLE>
well, until you get a alignment printout, there is no way of verifying the extent of damage
you said your steering wheel is crooked? if so, probaly the tie rod end, tie rod and steering rack could be damaged. you would have to replace any one of the broken components before getting an alignment check
jasrams
Honda Civic (2001 - 2005)
May 16, 2011 05:30 AM
BlackEG6
11
Nov 14, 2006 05:30 PM
Contender25
Oct 3, 2006 03:57 PM
illdiealonlyazn
Jan 27, 2006 12:03 AM
2001civ
Jan 1, 2003 01:33 PM
