Speed Sensor Question
Old Dec 12, 2005 | 08:57 PM
98IntegraLSNonVtec's Avatar
Default Speed Sensor Question
ok I've been having a problem with my speed sensor for a while the speedometer wouldn't rise except when I hit bumps then it worked for a while then stopped now it just doesn't rise at all even with bumps. The check engine light is also on so I ran the jumper wire and came up with "17" vehicle speed sensor code is it possible something might be disconnected if so where might that be? the connector is connected to the speed sensor I check that already. Thanks in advance for replies.
Old Dec 12, 2005 | 09:34 PM
JDM-EJ1's Avatar
Default Re: Speed Sensor Question (98IntegraLSNonVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98IntegraLSNonVtec &raquo;</TD></TR><TR><TD CLASS="quote">ok I've been having a problem with my speed sensor for a while the speedometer wouldn't rise except when I hit bumps then it worked for a while then stopped now it just doesn't rise at all even with bumps. The check engine light is also on so I ran the jumper wire and came up with "17" vehicle speed sensor code is it possible something might be disconnected if so where might that be? the connector is connected to the speed sensor I check that already. Thanks in advance for replies.</TD></TR></TABLE>
What kind of car do you have? Try cleaning it, 99% of the time that fixes it.
Old Dec 13, 2005 | 08:00 AM
Default Re: Speed Sensor Question (JDM-EJ1)
its a 98 LS. How would I clean it? with just water?
Old Dec 16, 2005 | 12:16 AM
gt30typer's Avatar
Almost without a dought you have had the same problem that has plagued many Honda's. Either the power wire or the signal wire becomes covered with corrosion, just like your battery does, this causes a poor connection and you speedometer to jump or not work at all. You can either replace the plug ( wires included) or pull out the corroded pin and replace it with a new one. Either way it is a pretty simple fix.
Old Dec 16, 2005 | 08:08 AM
JDM-EJ1's Avatar
Default Re: Speed Sensor Question (gt30typer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gt30typer &raquo;</TD></TR><TR><TD CLASS="quote">Almost without a dought you have had the same problem that has plagued many Honda's. Either the power wire or the signal wire becomes covered with corrosion, just like your battery does, this causes a poor connection and you speedometer to jump or not work at all. You can either replace the plug ( wires included) or pull out the corroded pin and replace it with a new one. Either way it is a pretty simple fix.</TD></TR></TABLE>
Old Dec 16, 2005 | 10:47 AM
which pin would I replace? where is it located?
Old Dec 16, 2005 | 04:36 PM
91IntegraX's Avatar
u got it easy i think...i have a DA with mechanical speedo...mynes broke...and the calbe is a stealership part so i just drive without now till i get money
Old Dec 17, 2005 | 10:10 AM
gt30typer's Avatar
If you look on your transmission you will find the VSS, it has a three pin connector on it. Disconnect the connector, take out the white plastic protector and then look at the three pins. One of the pins will look either greeny-blue with a little bit of white on it or it will look burnt. This is the pin that you need to replace. I believe that it is the center pin.
Old Dec 18, 2005 | 08:46 AM
loud_whispers's Avatar
yeah. more than likely if it's an intermittant operation( i.e ) over bumps ther eis a loose connection on either the VSS connector or the ground.
Old Dec 24, 2005 | 10:51 AM
Default Re: Speed Sensor Question (loud_whispers)
I checked my VSS yesterday and found out the middle pin was corroded and had broken off but was still in the connector loose any ideas on where to get a pin to replace it and how to do it? or should I just buy a VSS? thanks.
Old Dec 24, 2005 | 10:58 AM
gt30typer's Avatar
Radio Shack might have a pin like that. the easies way would be to cut it off another eninge harness or just pull a pin out of a plug. That pin is the same as the pins that connect the engine harness to the car harness on integras.
Old Dec 24, 2005 | 11:06 AM
ok thanks...after I get the pin should I solder it back? or is there an easier way?
Old Dec 24, 2005 | 11:52 AM
gt30typer's Avatar
If you get a pin with a lead on it , just solder the wires together. If not you are going to have to crimp the new pin onto the wire. I would run over the base of it with solder to make sure the connection will last.
DC2man
Mar 3, 2008 07:01 PM
supaf1y
Jul 30, 2007 09:16 AM
GdmLaz
Dec 4, 2004 04:00 PM
CaptainObvious
Aug 18, 2003 04:41 PM
