Engine kicks when decelerating.....
Old Dec 16, 2005 | 12:42 PM
P@@RB@Y's Avatar
Default Engine kicks when decelerating.....
Im guessing its the engine mounts or something.When I shift from first to second gear the engine slams back pretty hard.Its does hit anything but you can feel it kick back.That and if I suddenley let off the gas.
Does that sound like the engine mount?
Old Dec 16, 2005 | 02:18 PM
M Coop's Avatar
Default Re: Engine kicks when decelerating..... (P@@RB@Y)
Sounds about right. Poly kits are cheap and work well but transfer vibration a lot.
Old Dec 16, 2005 | 02:31 PM
Vtak DOHCTA's Avatar
same prob here...i got some energy mounts for like $20 bucks on ebay....i'm pretty sure they're easy to find elsewhere too...
Old Dec 16, 2005 | 02:42 PM
P@@RB@Y's Avatar
Default Re: (VtAkMn)
Anybody know if those TEIN engine dampers will make up for the vibration at idle?Or are do they serve a different purpose?
Old Dec 16, 2005 | 02:44 PM
lVlemphizStylez's Avatar
Default Re: (P@@RB@Y)
replacement oem or motor mount inserts are the ONLY things that will fix your problem...as well as maybe 3m window weld
sealz
Acura TSX
Mar 15, 2008 10:21 PM
lak8
Mar 2, 2008 09:44 AM
meno19
14
Aug 2, 2006 03:03 AM
ajth87
Apr 10, 2006 04:05 PM
h22 civic
May 31, 2004 02:21 PM
