weight reduction
Old Dec 12, 2005 | 08:23 PM
Clutch502's Avatar
Default weight reduction
what are good things to remove on a 2g integra to lightn it up?
Old Dec 12, 2005 | 08:26 PM
Stoich EG2's Avatar
Default Re: weight reduction (Clutch502)
front seat
rear seats
spare tire
carpet
sound deadening material
headliner
plastic interior peices
power steering
air conditioning
sunroof (if applicable)
lose weight yourself.
Elbowpunk's Avatar
lol... um seat(s) all types of panels.. ( all the back ones ).. spare tire....Seat belts...
Put your mind in it ... LOL
Old Dec 12, 2005 | 08:28 PM
Lauj87's Avatar
anything inside thats a accesorie!.....
Old Dec 12, 2005 | 08:32 PM
Clutch502's Avatar
Default Re: weight reduction (ADVAN EG2)
well say i already have that out what else could i take out
Old Dec 12, 2005 | 08:35 PM
Stoich EG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clutch502 &raquo;</TD></TR><TR><TD CLASS="quote">well say i already have that out what else could i take out</TD></TR></TABLE>
die hard ****:
your dash - get down and dirty with a sheet metal dash
windows
cut out skeleton of hood and doors
gas tank - get a smaller custom one.
LOSE WEIGHT YOURSELF - go running sucka
Old Dec 12, 2005 | 08:47 PM
projectTeG's Avatar
major stuff that i did was remove my entire ac system, remove the spare tire stuff from the hatch, removed the plastic floor panel and carpet from the hatch, aftermarket header, removed all stock intake piping, and lighter wheels. all toll ive removed around 130-160 lbs from my car. next i was thinking about removing the rear seats, rear panels, sound tar, and carpet.
Old Dec 14, 2005 | 08:23 AM
street_bliss's Avatar
I have a DC2 but things i have done is totally gottin rid of AC system including evaporator under dash. (i think that is the evaporator?) I also used an EG non power steering rack and got rid of all th power steering. Also i got rid of the power antenna and the hole setup and the rear wiper and total setup. But i kept my spare and **** cuase i got shitty tires. O and the most important join some old lady yoga class to essence the mind and soul. You will lose weight that way.
Old Dec 14, 2005 | 08:35 AM
CNSK's Avatar
run forest run...
Old Dec 14, 2005 | 08:41 AM
TRE_'s Avatar
Default Re: weight reduction (CNSK)
Unless you honestly need a wieght reduction, why bother? Just makes your car more uncomfortable, noisy and in the end doesnt really make a huge difference in 1/4mi or RR times... for a full out race car yes, but for a daily driver it seems stupid IMO.
Old Dec 14, 2005 | 09:41 AM
Sic_DA_Nine's Avatar
Default Re: weight reduction (TRE_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">Unless you honestly need a wieght reduction, why bother? Just makes your car more uncomfortable, noisy and in the end doesnt really make a huge difference in 1/4mi or RR times... for a full out race car yes, but for a daily driver it seems stupid IMO.</TD></TR></TABLE>
i agree
if your car is a daily driver...then to you!
if its for track only, i suggest you remove everything that is not neccessary for the car to drive...
gut door panels, no windows, lexan glass in rear and quarter panel, remove AC and PS, seats, carpet, dash, spare tire, cut a hole where the spare tire is gunna be, just remove everything!!
Old Dec 14, 2005 | 11:33 AM
92gisser's Avatar
my thoughts, exactly
Old Dec 14, 2005 | 11:50 AM
xplanetearth420x's Avatar
this has been discusted so many times so just try clicking the search botton
Old Dec 14, 2005 | 12:45 PM
Dutch-VTEC's Avatar
Default Re: weight reduction (xplanetearth420x)
weight reduction is good and all. I did it to my 88 hatchback. Took the entire dash and ac and heater out. It is only good to a certain extent. You should probably worry a little more about traction. All horsepower and no traction= a loud slow piece of s***.
Old Dec 14, 2005 | 01:01 PM
JeffRocksYoSocks's Avatar
hahah lose weight GO RUN!
hit up the sauna for a couple hours, lots of water!!!
If youre really serious about losing weight, you can do what my friend did. Cut the whole spare tire area out, cover it with sheet metal and weld it.
Cut the inner rear quarter panels
Fiberglass doors
lexan windows
If you do this i would highly recommend getting a cage.
Old Dec 14, 2005 | 01:02 PM
fur elise's Avatar
haha lose weight yourself.
nice.
Old Dec 14, 2005 | 01:33 PM
nickG's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">major stuff that i did was remove my entire ac system, remove the spare tire stuff from the hatch, removed the plastic floor panel and carpet from the hatch, aftermarket header, removed all stock intake piping, and lighter wheels. all toll ive removed around 130-160 lbs from my car. next i was thinking about removing the rear seats, rear panels, sound tar, and carpet.</TD></TR></TABLE>
you get a new exhaust yet??
Old Dec 14, 2005 | 05:51 PM
ckyguy's Avatar
-header is quite a bit lighter than stock manifold
-lightweight battery
-fabricate aluminum mounts for accessories on engine (cast ones = heavier than you think)
-everything said before but most of that sacrifices luxury, these don't
-heat shields
Old Dec 14, 2005 | 07:29 PM
projectTeG's Avatar
Default Re: (nickG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickG &raquo;</TD></TR><TR><TD CLASS="quote">you get a new exhaust yet??</TD></TR></TABLE>
nope still running the stocker, i just have a test pipe on it. i forgot to add i am also running a dc/eg sized battery because the da's had huge accord sized batteries...so i lost some weight there too.
b18c195
Nov 30, 2007 05:59 AM
litterbox
116
Oct 15, 2005 08:40 AM
PhoebeusFenix
Mar 7, 2005 04:59 AM
ScareyH22A
Jul 26, 2003 06:01 PM
MikeExt
22
Oct 10, 2002 01:59 PM
