Bore Size
Old Aug 1, 2007 | 02:12 PM
Ra GS-R's Avatar
Default Bore Size
any way to tell what size ur bore is on a usdm gsr, w/out tearing down the motor and measuring? i want b16b pistons but dotn know whether to get std bore or .25 over bore.
Old Aug 1, 2007 | 02:23 PM
myfirstdc2's Avatar
Default Re: Bore Size (Ra GS-R)
LOL std means standard bore which is 81mm stock cuz its standard! o/s means 81.25mm because its oversized. it pretty much expalins itself when something says the word "oversize" meaning its bigger.
Old Aug 1, 2007 | 02:26 PM
VTEC_PRODUCTION's Avatar
Default Re: Bore Size (myfirstdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myfirstdc2 &raquo;</TD></TR><TR><TD CLASS="quote">LOL std means standard bore which is 81mm stock cuz its standard! o/s means 81.25mm because its oversized. it pretty much expalins itself when something says the word "oversize" meaning its bigger. </TD></TR></TABLE>
you got it...
Old Aug 1, 2007 | 02:37 PM
DAmnquickDA's Avatar
Default Re: Bore Size (VTEC_PRODUCTION)
instead of "tearing down the motor"... you could just look up specs on it. this **** is all over the net. seriously, go type "b18 bore" in yahoo or google and you will get over 30,000 hits. BTW all b series are 81mm with the exception of the B20 and i think the old prelude b motors.
Old Aug 1, 2007 | 02:39 PM
goota's Avatar
you got a pm
Old Aug 1, 2007 | 04:59 PM
Ra GS-R's Avatar
Default Re: (goota)
yeah i know what it is i just thought some where different
Old Aug 1, 2007 | 09:37 PM
Ra GS-R's Avatar
Default Re: (Ra GS-R)
ok i found out the the gsr had std bore size thanks guys
Old Aug 1, 2007 | 09:51 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ra GS-R &raquo;</TD></TR><TR><TD CLASS="quote">ok i found out the the gsr had std bore size thanks guys</TD></TR></TABLE>
umm, standard bore for all b series minus b20's is 81mm. honda only offer's oversized pistons in case you need a slight overbore to clean up the cylinders when doing a rebuild.
xsenceo89x
Apr 8, 2011 02:18 PM
Teamdiesel
Aug 6, 2008 06:51 PM
thollis97
Jan 22, 2007 05:22 PM
MilanoFury
Jul 10, 2004 11:00 PM
JDM97R
Dec 27, 2003 09:08 AM
