big big firewall problem
Old Jul 29, 2007 | 04:06 PM
Tegraracer90's Avatar
Default big big firewall problem
i was drilling a hole under were the clutch goes through the firewall for my amp wire....and i drilled it fine with no problems....now tonight i drilled a hole right under it...and the drill drilled through a thin piece of sheet metel...and then i guess started to drill threw the actual firewall?.....and then all of a sudden the bit started twisting wires around it...i quick pulled the drill out and it cut two wires and they came out on the bit......it was the wire for the right turn signal.....anyone know how i get to these wires??
Old Jul 29, 2007 | 06:54 PM
12sGSR
Guest
Posts: n/a
Default Re: big big firewall problem (Tegraracer90)
way to go is that ur first amp that u tried to put on u should have look theres a place to run a amp wire in every car good luck
Old Jul 29, 2007 | 08:03 PM
myfirstdc2's Avatar
why would u drill a hole when u couldve just put it thru the grommet. also u can just repair the wire solder and heat shrink and some wire. thats all u need
Allurian
Audio / Security / Video
Aug 8, 2008 09:40 AM
Odessa
19
Jul 23, 2004 07:55 PM
Full Race A6
Mar 13, 2004 12:40 AM
CoolKat
Mar 13, 2003 10:02 AM
REDMAN1322
Oct 20, 2001 09:30 AM
