My setup
Old Jul 31, 2007 | 12:45 AM
Nicks95GSR's Avatar
Default My setup
I have a plan on to what to do next to my car. Im going to go all motor N/A. Im planing of getting the following...
*Cams A
*Intake manifold
*cam gears
*timing kit
*clutch
*valve springs
*intake and exhaust valves
* then port and polish
I want to be at around 210HP-250HP. What else would I have to do to reach my goal. Oh yeah I want all everything to be legal and i want my car to pass smog. I dnt want to swap my car
THANX HT-MEMBERS!!!
Old Jul 31, 2007 | 01:27 AM
rayray NOT shanaynay's Avatar
Default Re: My setup (Nicks95GSR)
no way your car would be legal. you can only do so much for your car to still pass smog.. like buy carb parts and such but it really isnt worth it. build it right and find someone to smog it for you
Old Jul 31, 2007 | 01:47 AM
Lauj87's Avatar
Well to get up to 250hp your gunna need alot more then that. but the 210 is do able and you can still stay with in smog spec with it. First thing is buy all carb legal parts. then Tuning is the biggy. if your in the san jose area you should check out blacktrax they do alot of good work.
Old Jul 31, 2007 | 06:03 AM
kevpotts's Avatar
Default Re: (Lauj87)
you're gonna need to go high compression to reach 210. pretty damn high. and odds are it will not be legal.
250 is pretty much impossible. its not impossible, but it is.
you may also want to bore it out to 2.0L
go big or go home
Old Jul 31, 2007 | 08:33 AM
Schister66's Avatar
Man U FTW
no way you'll hit 210 w/o internals, but good luck....SMOG is going to slow you down as well
Old Jul 31, 2007 | 10:41 AM
doood's Avatar
been there done that
Default Re: (Schister66)
sticking with CARB legal parts to stay legal, you'll be nowhere near 210whp.
Old Jul 31, 2007 | 11:03 AM
Nicks95GSR's Avatar
I want to get all internals but I dont know what else im going to need to buy. So if you could help me out on this one that would be koo!!!
Old Jul 31, 2007 | 11:42 AM
jay_cue's Avatar
Default Re: (Nicks95GSR)
if you still want to be able to smog your car, go with the edelbrock turbo kit part #1505. kinda pricey but should get you 250 whp and still be able to smog your car legit.
Old Jul 31, 2007 | 01:24 PM
Nicks95GSR's Avatar
Default Re: (jay_cue)
I wanna go all motor
Old Jul 31, 2007 | 10:27 PM
Nicks95GSR's Avatar
Old Jul 31, 2007 | 10:35 PM
EARLdaSQUIRREL's Avatar
official honda whore
to be able to get anywhere close to the power you want you will have to start with this as a base:
84 or 85 mm bore sleaved block
ported head with a ported itr intake manifold with the tb bored by maxbore
then you will have to find the best carb legal parts you can such as:
aem cold air intake for type r (3")
carb legal header
highflow cat
carb legal exhaust
im not sure which cams you could use and still be able to pass the smog test so you will have to research them on your own, good luck 200whp isnt easy, let alone doing it in california and keeping it legal
Old Aug 1, 2007 | 12:05 AM
Lauj87's Avatar
Default Re: (coptzer)
He could use skunk2.
HONDATA IS YOUR FRIEND!!
Old Aug 1, 2007 | 08:14 AM
Schister66's Avatar
Man U FTW
Regardless of the engine build, you're still going to have a hard time making the power you want AND keeping your car CARB legal. Honestly, your best bet is to buy a CARB legal turbo setup....they're way overpriced, but that's what you get in California....
Old Aug 1, 2007 | 08:25 AM
SlammedDC2's Avatar
Semper Fidelis
I am building an all motor set up myself. however to hit 210+ your not going to be legal and your going to have to spend some money, get some machine work, bore, stroke, etc. etc. however good luck with the build. when the search feature is back up search the all motor forum, and do some reading in there. i spend most of my time in that area and read everything I can.
Old Aug 1, 2007 | 08:49 AM
fergy016's Avatar
Default Re: (SlammedDC2)
The high compression pistons 12:1-13.5:1 you would have to use would make you detonate during smog with an oem ecu, so you would have to run high octane unleaded fuel.
The cams you would have to run would not be street legal as well to make the power your planning on making.
Your injectors will also top out and have to be upgraded so you don't run lean in the top end, and there is no legal way to do that, or way to run an oem ecu with oversized injectors.
Hope this helps, changing a few things during smog time isn't all that difficult if you really want to obtain your power goals.
By any means I am not condoning doing that...
99cxrico
Jan 18, 2005 11:27 PM
Thrillhouse
Jul 22, 2002 11:13 AM
G2Integrity
Jul 3, 2002 02:29 PM
B00ST2nR
May 20, 2002 12:26 PM
comptechgsr
May 13, 2002 01:41 PM
