Check Engine Light Code 54
Old Aug 1, 2007 | 09:11 PM
drive4aliving's Avatar
Modified by drive4aliving at 11:35 PM 8/14/2007
Old Aug 2, 2007 | 04:54 AM
g0tgot's Avatar
sounds important.....
Old Aug 2, 2007 | 06:54 AM
93dagsr's Avatar
https://honda-tech.com/zerothread?id=1901557
Old Aug 2, 2007 | 09:52 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: (drive4aliving)
buy a new sensor? If your CEL comes on for the o2 sensor, what are you going to do? Buy a new sensor.
Old Aug 2, 2007 | 10:19 AM
tamparacer's Avatar
Default Re: Check Engine Light Code 54 (drive4aliving)
The crankshaft fluctuation sensor is on the oil pump on an OBD2 engine. The wires are white/red and blue/red on the car side and white and blue on the sensor side of the plugs on 98+ integras. Look below/around the alt. You will find the plug coming from the timing cover. Maybe its unplugged. Doubt it's bad, but maybe it is. I have never had one go out myself. I've had a honda or 2 since 98.
I assume you are using the 98 ecu?
Modified by tamparacer at 11:33 AM 8/2/2007
Old Aug 2, 2007 | 10:30 AM
tamparacer's Avatar
I would also suggest at least a Haynes manual for about $13 before you go buying sensors. All of the info I gave you and more in the book about that sensor.
Old Aug 7, 2007 | 03:50 AM
tamparacer's Avatar
Where did you find the wires at? Bottom of the timing cover?
Old Aug 7, 2007 | 12:24 PM
tamparacer's Avatar
Can you get a pic?
Old Aug 7, 2007 | 12:25 PM
1.8L_allmotormilitia's Avatar
I think that sensor is on the oil pump. On obd2 they moved the crank sensor out of the distributor onto the oil pump.
Old Aug 7, 2007 | 12:31 PM
tamparacer's Avatar
Default Re: (1.8L_allmotormilitia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8L_allmotormilitia &raquo;</TD></TR><TR><TD CLASS="quote">I think that sensor is on the oil pump. On obd2 they moved the crank sensor out of the distributor onto the oil pump.</TD></TR></TABLE>
That is correct.
ArkCRV
Honda CR-V & Element
May 6, 2015 04:51 AM
mtime
Dec 17, 2009 09:17 PM
ORcivicsi
Jun 22, 2005 08:43 PM
ORcivicsi
Jun 19, 2005 06:19 AM
shauniewalnuts
Mar 8, 2003 02:17 PM
