VTEC problem help!!!!
Old Jul 30, 2007 | 05:04 PM
210jdmgsr's Avatar
Default VTEC problem help!!!!
Hey, i just bought a 97 gsr, when i first drove it the vtec wasnt kicking in all the time and when it did it was around 6k. Well i checked my oil and it was really low. I put some oil in it about 3/4 a quart and it read on the dip stick half way between the dots wierd? Well i took it back out and drove it again and it hits vtec every time but still at 6k or a little over that. I thought they were supposed to kick in aroudn 4 to 5k. Can any one tell me what the problem might be.
P.S. the check engine light works but doesnt come on.
Old Jul 30, 2007 | 05:09 PM
DAmnquickDA's Avatar
Default Re: VTEC problem help!!!! (210jdmgsr)
GSR vtec does engage at 4400 but since the IABs havent opened yet you still have restricted airflow. thus, when the IABs do open at 5800 you feel the power difference more. Sounds like you didnt have enough oil though
Old Jul 30, 2007 | 05:11 PM
210jdmgsr's Avatar
Default Re: VTEC problem help!!!! (DAmnquickDA)
what are the IAB's?
Old Jul 30, 2007 | 05:39 PM
posHonda's Avatar
they are located in the intake manifold. if youre stock or not far from it than leave them alone.
vtec on a gsr will engage at 4400rpm and its hardly noticeable at all.
Old Jul 30, 2007 | 05:55 PM
Blahblah718293's Avatar
Default Re: (iVteC_PoWeR)
VTEC engages at 4400 rpm but your not really suppost to hear it that much, the sound your hearing is your secondary runners in the intake manifold opening up at 5800 rpms. this system is in place to keep a flat torque curve all the way through the power band.
read this before you ask anything else
http://www.team-integra.net/se...ID=45
210jdmgsr's Avatar
i can hear the motor make a big noise difference around 6k is that the vtec kicking in or what. i also head someboddy saying somthing about butterfly valves or somthing opening up at 5800rpm do you think thats what im talking about.
Old Jul 30, 2007 | 06:00 PM
posHonda's Avatar
we just told you.
at 5800rpm the secondaries will open (IAB, butterflies, whatever) and thats the change in tone that you hear. vtec engages at 4400 on a gsr.
Old Jul 30, 2007 | 06:07 PM
210jdmgsr's Avatar
thanks man i didnt mean to sound repetitive i just didnt see the second part of what you wrote. But thanx for the info i was afraid my Vtec was f#@$ and it was worring me because i just got it yesterday.
Old Jul 30, 2007 | 06:11 PM
Default Re: (210jdmgsr)
GSR motors have the only semi-linear B series powerband. A good set of cams, skunk 2/blox/itr IM and a tune will change that. Less torque, but a lot more on the top end and there will be no question as to when VTEC engages. You will notice.
Old Jul 30, 2007 | 06:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 210jdmgsr &raquo;</TD></TR><TR><TD CLASS="quote">i can hear the motor make a big noise difference around 6k is that the vtec kicking in or what. i also head someboddy saying somthing about butterfly valves or somthing opening up at 5800rpm do you think thats what im talking about.</TD></TR></TABLE>
did you read the link? incase not ill post it again
BMO98GSR
Mar 31, 2010 07:01 AM
95gsr_integra
Apr 10, 2006 11:16 AM
greddy13
Oct 24, 2005 10:40 AM
Lauj87
Jun 28, 2005 11:46 AM
DocV
Jan 10, 2003 06:58 PM
