Got computer problems on 95gsr..............check engine light
Old Aug 1, 2007 | 10:34 PM
rotascircuit's Avatar
Default Got computer problems on 95gsr..............check engine light
Hey I have a check engine light I did the jumper wire thing and it gave me codes 23 and 41 does anybody know what I need to change or fix or know what the codes are? also srs does anybody know how to clear that manualy? rotascircuit@yahoo.com THANX
Old Aug 1, 2007 | 10:47 PM
my_hidden_romance's Avatar
Default Re: Got computer problems on 95gsr..............check engine light (rotascircuit)
41 Primary oxygen sensor heater
23 Knock sensor
search for the srs thing.. i think i read something on here yesterday about it
Old Aug 1, 2007 | 11:07 PM
nA_Gsr303's Avatar
http://www.team-integra.net/se...=1128
Old Aug 1, 2007 | 11:33 PM
Default Re: (GSRDC2)
totalimmortal
MalleusMaleficarum
DIY SCS Service Connector and SRS Reset
An SCS Service Connector is used to reset your SRS light, which every Honda owner will eventually end up having to do. The dealer charges anywhere from $65 to $95 to do this, I'll show you how to do it for under $10.00. First you need to go to Best Buy or Circuit City and pick up some late model Honda speaker harnesses by Metra. The Metra model number is 72-7802. Cut the female disconnects off the ends of the speaker harnesses and strip about a half inch of jacket off of the wire. Twist the wire together and tape up the bare wire, you now have an SCS Service Connector for quite a but less than what Honda would have charged for one.
Now I'll show you how to reset the light. We've allready done the 1st step by making the SCS Connector.
You'll need to find the MES (Memory Erase Signal) connector.
It is a yellow connector with two wires in it that is plugged into the back of the driver's side fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. Here's a diagram for clearer understanding.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
It worked first time for me. If it doesn't work first time, try again. The timing has to be pretty precise. Doing it with the connector I made is much easier that using a paper clip to jump the connector. Good Luck
***you beat me to it.. thanks!***
alexisthemovie
Honda Civic (2001 - 2005)
30
Aug 11, 2014 07:53 AM
xlusiveracer
Feb 8, 2012 05:59 AM
vtecDadC2
Nov 17, 2006 09:35 AM
Red2001GSR
Feb 19, 2002 10:28 PM
