Lowering Springs problem
Old Feb 16, 2008 | 09:24 PM
david itr's Avatar
Default Lowering Springs problem
Okay guys, i have a set of eibach sportline lowering springs on one of my integras..well the back is lowered pretty good but the front is really high, like stock height if not, higher even. I was wondering do they need time to weaken and settle down, or are they just designed for the front to be higher than the rear?
Old Feb 16, 2008 | 09:35 PM
supracrx's Avatar
u sure u didnt mix the springs? front and rear? i heard of lot of people doing that...putting front springs in the rear, and vice versa...i think the rears are suppose to be lower.
Old Feb 16, 2008 | 09:37 PM
yc_dc4mar's Avatar
Default Re: (supracrx)
i have sportlines and the springs in the front are higher than the rear. if you look at your car it should look straight according the the side moldings or body lines. i hate it too. your not alone.
the front should be a bit lower than stock though. it might need to settle. bought mine used.
Old Feb 16, 2008 | 09:39 PM
david itr's Avatar
Default Re: (yc_dc4mar)
no bc the i put the stiffer ones in the front..and the stiffer ones should be in the front to hold all that weight..
Old Feb 16, 2008 | 09:47 PM
yc_dc4mar's Avatar
Default Re: (david itr)
they say front and rear on them. dont mix them up. i think the front ones are a bit stiffer though. i dont remember
Old Feb 16, 2008 | 10:41 PM
Lasty K's Avatar
I believe it's how the wheel lines are cut or something like that. If you look at the sideskirt, it'll be even to the ground. But the rear will look lower cause the 'wheel' line is cut lower than the front.
Something like that.
Old Feb 16, 2008 | 11:07 PM
TightEyez's Avatar
Default Re: (Lasty K)
post pics?
Old Feb 17, 2008 | 04:04 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Lowering Springs problem (david itr)
Is the perch height on your shocks adjustable?
Old Feb 17, 2008 | 06:27 AM
91b20bintegra's Avatar
i just bought skunk2 lowering springs for my car and it does the same thing.. hell i even took them off and switched them thinking i put them on wrong. but to my surprise it was right the first time..
rekreb38
Suspension & Brakes
Nov 3, 2010 10:30 AM
EM2_Kid
Honda Fit
10
Sep 2, 2009 08:31 PM
randerson0248
Jun 29, 2008 02:26 PM
Wazup
Suspension & Brakes
Feb 6, 2006 10:46 PM
bseries_beast
Suspension & Brakes
Jan 11, 2005 09:01 PM
