Fluids
Old Feb 17, 2008 | 12:43 PM
sh4mr0ck's Avatar
Default Fluids
Alright, so I normally run 91+ octane in my GSR for fuel, but what kind of motor oil should I run? I've been running Royal Purple 5W-30, anything you guys have had good luck with?
What about tranny fluid? I've heard the Royal Purple tranny fluid is pretty good too...
Also, brakes and clutch, DOT3 or DOT4? What do you think?
As for coolant I usually run 40/60 (Coolant/Water), what about you?
Old Feb 17, 2008 | 12:50 PM
HONDRETTI's Avatar
Default Re: Fluids (sh4mr0ck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sh4mr0ck &raquo;</TD></TR><TR><TD CLASS="quote">Royal Purple 5W-30 </TD></TR></TABLE>
Old Feb 17, 2008 | 01:22 PM
sh4mr0ck's Avatar
Default Re: Fluids (HONDRETTI)
Well, I know I'm right in the fuel, oil, and coolant fields, then
What about tranny fluid, brake fluid, and clutch fluid?
Also, is it a good idea to flush your clutch fluid if it looks milky?
Old Feb 17, 2008 | 04:28 PM
PrinceAli132's Avatar
Personally I use:
Motor Oil = Valvoline Synthetic (bought it on sale 5 bucks for a gallon and picked up 15 gallons)
Coolant = Honda
Brakes = ATE Super Gold/Blue (DOT 4 should be fine for daily use).
Clutch = Dot 4 Brake Fluid (can't remember which brand).
Ali
Old Feb 17, 2008 | 04:31 PM
Mcdc2's Avatar
I use 10w-40 Penzoil because Royal Purple was too thin and kept burning it like water and coolant I usually use 50/50. 198k miles on it and it still runs like a champ
Old Feb 17, 2008 | 05:57 PM
sh4mr0ck's Avatar
Default Re: Fluids (PrinceAli132)
I would be able to use the ATE Blue racing fluid in my clutch as well, right?
Old Feb 17, 2008 | 06:33 PM
sh4mr0ck's Avatar
I forgot about PS fluid as well, anything special I can dump in there after a flush?
Old Feb 17, 2008 | 06:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sh4mr0ck &raquo;</TD></TR><TR><TD CLASS="quote">I would be able to use the ATE Blue racing fluid in my clutch as well, right?</TD></TR></TABLE>
no prob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sh4mr0ck &raquo;</TD></TR><TR><TD CLASS="quote">I forgot about PS fluid as well, anything special I can dump in there after a flush?</TD></TR></TABLE>
im sure just about anything will be fine
Ali
Old Feb 17, 2008 | 07:02 PM
sh4mr0ck's Avatar
Alright, thanks!
Do you think the royal purple Synchromax tranny fluid is pretty good, too?
Old Feb 17, 2008 | 07:17 PM
Never used it.
I am using some Amsoil stuff and it works well with my LS tranny. When I flushed it after 7 months and 2 track events it came out looking pretty good still.
Edit, my buddy uses it in his dedicated track R and has no problems yet and loves it, he said he had some problems at the end of a session with grinding before switching to amsoil.
Ali
Old Feb 17, 2008 | 07:18 PM
sh4mr0ck's Avatar
Alright, thanks for all the help!
Old Feb 17, 2008 | 07:41 PM
jhammond_82's Avatar
Reject Papi
i've never used anything other than havoline.
Old Feb 17, 2008 | 07:46 PM
db8gsr_teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sh4mr0ck &raquo;</TD></TR><TR><TD CLASS="quote">Alright, thanks!
Do you think the royal purple Synchromax tranny fluid is pretty good, too?</TD></TR></TABLE>
do not use the royal purple synchromax on your tranny . i remember before using these my tranny was fine until i put these in my tranny and it started grinding in some of my gears. same thing happened to my bro's too.
Old Feb 18, 2008 | 11:43 AM
sh4mr0ck's Avatar
Default Re: Fluids (db8gsr_teg)
Alright, I might try to get some of that Honda MTF, then, I've heard that's pretty good.
Old Feb 18, 2008 | 02:17 PM
1dumbscreenname's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sh4mr0ck &raquo;</TD></TR><TR><TD CLASS="quote">Alright, I might try to get some of that Honda MTF, then, I've heard that's pretty good.</TD></TR></TABLE>
I heard GM synchromesh is really good. But I used the Pennzoil synchromesh a while back and it worked great on a different car I had.
I run 15-50w Mobil 1 on my boosted GSR and I never leak or burn a drop.
Honda Coolant is the only way to go
DOT 3 is what I believed to be best for dd use, but I may be wrong
edit:: coolant percentage depends on where you live. here in fla I can run less coolant and more water because it doesnt freeze here, but in ND your obviously gonna freeze so you run a 50/50 mix
Old Feb 18, 2008 | 03:11 PM
sh4mr0ck's Avatar
Default Re: Fluids (1dumbscreenname)
Yeah, but in the summer it gets fricken hot here, so I try to get a higher percentage of water in the summer in my coolant just so it runs a little cooler...
Old Feb 18, 2008 | 07:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sh4mr0ck &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, but in the summer it gets fricken hot here, so I try to get a higher percentage of water in the summer in my coolant just so it runs a little cooler...</TD></TR></TABLE>
so you flush your rad 2wice a year?
Old Feb 19, 2008 | 04:41 AM
sh4mr0ck's Avatar
Yeah, winter here gets to -20 F without the wind chill and our summers get to 110 F without humidity, meaning here in North Dakota we're getting the extremes of about -45 F to 125 F and it isn't good...
So I don't fully 'flush' my radiator twice a year, I only flush it once a year, but I dump it out and fill it with a different mix at the end of winter... I also reset my ECU twice a year, change my rims twice a year, and adjust throttle position twice a year...
I clean my air filter and breather once a month as well, wash my car once a week in the winter (salt and sh*t make 'er rust) and whenever it gets too dirty in the summer...
Old Feb 19, 2008 | 10:57 AM
lil23pinoy's Avatar
just a Q. for you guys...How bad is it to switch from Synthetic oil to reg oil? Just bought a ls/vtec and the guy used synthetic. personally I dont like it...can I switch over slowly (use 2 bottles of synthetic and 2 of reg, and just eventually switch to reg) OR will this really ruin the rings pretty bad???
tnx
Old Feb 19, 2008 | 01:47 PM
sh4mr0ck's Avatar
Default Re: (lil23pinoy)
Honestly, I've heard that once you use synthetic you can't use regular oil... but I've never had a problem with putting whatever in... I do regular compression tests and check my blow-by all the time and there never seems to be a problem...
Most recently I've stuck to synthetic, Royal Purple 5W-30, so I don't worry any more, but as stupid as this sounds I see it as: oil is oil... lol
Old Feb 19, 2008 | 02:23 PM
Rainmaker's Avatar
I used synthetic for years and then went back to regular when I realized I was just throwing my money away (given my driving routine). I made the switch at about 100k miles. Car is over 135k now and no consumption/leakage problems.
Old Feb 19, 2008 | 02:47 PM
Jimmy's Avatar
Global Moderator
Motor Oil: Castrol, or any valvoline product
Brake fluid: Any dot 3 or dot 4
Tranny fluid: Honda MTF or pennzoil syncromesh
Coolant: Auto zone or advanced cheap 50/50 mixed
Old Feb 19, 2008 | 04:42 PM
lil23pinoy's Avatar
sounds good tnx!
Seems to b that everytime i talk to someone that really seems like they know what there doing...they reply with "thats a bad idea cuz it will make the rings go bad" but I guess ill give it a try...tnx!
Old Feb 19, 2008 | 07:33 PM
sh4mr0ck's Avatar
Good luck with the oil, dude, just remember that sometimes the only way to learn something is the hard way... so be careful. Like I said, I've never seen a problem with it, but I've heard experienced techs say its bad...
xintegr
Aug 7, 2007 03:19 PM
crxforum
Jun 30, 2007 09:58 AM
whiteboy03si
Mar 7, 2007 08:03 PM
teddy_dc2
Nov 21, 2005 12:03 PM
Xgen
14
Sep 15, 2004 08:49 AM
