DA distributor into DC
Old Feb 15, 2008 | 12:02 PM
matmcg's Avatar
Default DA distributor into DC
Are they interchangable
B18A to B18B ??
I need a new distributor but not sure which cars i can take from
Old Feb 15, 2008 | 12:20 PM
matmcg's Avatar
Default Re: DA distributor into DC (matmcg)
bump
Old Feb 15, 2008 | 12:26 PM
matmcg's Avatar
Default Distributor Interchangability
Need to put a new Dizzy in a 1995 Integra
which other models can i use
Can i use a dizzy from a DA?
Old Feb 15, 2008 | 12:35 PM
deftonerider's Avatar
if its a 92-93 da distributor it should work assuming its going into a 94-95 dc because they are both obd1
Old Feb 15, 2008 | 12:37 PM
matmcg's Avatar
Okay cool cuz im going to pick one up for 45 bucks out of a 92 b18b
and its going into a 95 b18b ( but it had a jdm swap) is this a factor?
Old Feb 15, 2008 | 12:58 PM
i dont' think so because i have a 91 integra and had a b20 motor running off of a obd0 ls computer and ls obd0 distributor so if you are using a obd1 ls computer and an ls obd1 distributor it should be just fine
just in case double check with a buddys distributor first
Old Feb 15, 2008 | 03:08 PM
thewrai6th's Avatar
Default Re: Distributor Interchangability (matmcg)
Since you are not getting any response, I would say to start looking at part numbers and help yourself.
If they are the same #, it's usually the exact same part. If they are different #'s then they probably wont work.
http://www.acuraautomotiveparts.org/
What block does your 95 have in it?
Old Feb 15, 2008 | 03:16 PM
matmcg's Avatar
B18B block
I jsut a picked up a dizzy for 45 bux the guy said it was from a DA but the harnesses dont match up I will need to rewire i guess
Old Feb 15, 2008 | 03:44 PM
DA_9's Avatar
Default Re: (matmcg)
No dizzys do not match all the time. OBD0 is different from OBD1. Same goes for vtec; you cant use a vtec dizzy on non vtec car. Go to Rywire.com you may find a harness for the obd 0 to obd1 distributor.
Old Feb 15, 2008 | 03:48 PM
DA_9's Avatar
Default Re: (deftonerider)
Stop double POSTING. you only need one post. Yeah and if the wiring doesnt match, which I know it wont, he just sold u a 91 dizzy.
Old Feb 15, 2008 | 04:48 PM
all-mtr-teg's Avatar
Default Re: (DA_9)
Yup, that's what Im assuming also.
Old Feb 15, 2008 | 04:58 PM
Max500's Avatar
I have personally tried this and I can asure you that it works perfectly fine as long as they are both OBD1. DA tegs 92-93 are OBD1.
Old Feb 15, 2008 | 05:05 PM
thewrai6th's Avatar
Default Re: (Max500)
He probably got one from a 91, it doesn't match and DA_9 posted the solution:
http://www.rywire.com/store/im...r.gif
That should do it.
RxglassJAw
Dec 19, 2007 02:47 PM
MrEg
Jun 28, 2006 09:50 PM
14bcoupe
Jul 23, 2005 05:46 AM
