Partial throttle?...
Old Feb 14, 2008 | 05:24 PM
VTECth1s's Avatar
Default Partial throttle?...
My partial throttle on my gsr is quite annoying. It happens between 3-5k rpm in 3-5th gear. When I put partial throttle, I feel a bit of lag and within a second or 2 it goes back to normal. No CEL's, motor is completely bone stock. And it's had a full tune-up recently, also it has around 50K miles. I assume it could be the throttle cable or something. Any idea's? Help would be appreciated
Old Feb 14, 2008 | 05:30 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Partial throttle?... (VTECth1s)
What ECU are you running?
Old Feb 14, 2008 | 06:22 PM
VTECth1s's Avatar
Default Re: Partial throttle?... (Dogginator)
Last time I looked it said P72. But on the ECU, there was a marker written "92-95 automatic ecu". But it clearly said P72, hmmm?? But I do know the car was originally an automatic, then converted to manual with the gsr swap. Btw this is a 96 EJ6 hatchback.
Old Feb 14, 2008 | 08:54 PM
VTECth1s's Avatar
bump!
Old Feb 14, 2008 | 11:40 PM
DA_9's Avatar
FUel Filter, mayb fuel system. Sounds like that or a Air to Fuel ratio problem, im guessin thats where Dogginator was headed with his question.
Old Feb 15, 2008 | 09:38 AM
VTECth1s's Avatar
Default Re: Partial throttle?... (DA_9)
Good to know, I'll get the fuel filter changed. The fuel system was cleaned during the tune-up. Maybe I should try another ECU? like another P72?...hmm
Old Feb 15, 2008 | 09:09 PM
VTECth1s's Avatar
bumpage
sean2000gt
May 22, 2014 06:35 AM
raverx3m
Jul 9, 2012 09:03 AM
poopoohead
Jun 15, 2010 04:45 PM
echo999
Oct 23, 2002 07:13 AM
95civicSI
Jun 18, 2002 05:10 PM
