crank pulley issue?!?!
Old Apr 18, 2008 | 08:59 AM
type-GGSR's Avatar
Default crank pulley issue?!?!
i recently started to feel that my car vibrates during low rpms. At higher rpms, its not that noticable. I looked in the engine bay to find that my crank pulley seems to be wobbly (cant spell ). Should i just try to tighten it becuase its loser? Or can someone tell me whats wrong?
Old Apr 18, 2008 | 09:22 AM
JETSPD1477's Avatar
Default Re: crank pulley issue?!?! (type-GGSR)
its possible that it is coming loose or the pulley has worn out. doesn't hurt to get in there and check.
Old Apr 18, 2008 | 09:45 AM
type-GGSR's Avatar
Default Re: crank pulley issue?!?! (JETSPD1477)
should i try tightening that nut at first?
Old Apr 18, 2008 | 09:56 AM
super jdm yo's Avatar
when you say wobbly.. is it like it's not tighten all the way because those things are on there with teeth so if it was loose i would think that it can only slide side to side. there's a pin that you should check for in there. that might have caused the problem.
Old Apr 18, 2008 | 07:03 PM
Bignel00's Avatar
i had the same issue , my crank pulley kept getting loose , come to find out that the previous owner messed up the threads. I just cleaned the treads as good as i could and i bought a brand new bolt , and a new crank pulley,(because mine worn out because of it being loose) . o ya ls crank pulley works ok to .
devilpuppy
Aug 30, 2024 09:15 AM
civikdude
Feb 13, 2009 02:17 PM
grey_ghost
Mar 12, 2008 12:52 PM
white_panther
Dec 8, 2006 04:47 PM
