difficulty level of ls engine
Old Apr 16, 2008 | 10:56 AM
2ndchirp's Avatar
Default difficulty level of ls engine
how hard would it be and how long to take out an LS engine with the proper tools... the thing is my car is my daily driver and im gettin 3 free days to swap out my 1994LS for a 99LS engine... im not that new to this ..i've swapped engines of some preludes which is the only eperience that i have...
Old Apr 16, 2008 | 07:55 PM
2ndchirp's Avatar
bump
Old Apr 16, 2008 | 08:24 PM
da itr-t's Avatar
Default Re: (2ndchirp)
Ive done quite a few r&rs on integras. Mostly da's but i've done 2 dc2s. never kept too much track of time, but to take one out (added everything goes smoothly) i'd say noo more than 4.5 hours. So figure to replace 5.5 max. Thats with taking your time. Three days would be more then plenty, excluding the fact that your putting an obd2 motor in an obd1 car..
Old Apr 17, 2008 | 09:06 PM
2ndchirp's Avatar
Default Re: (da itr-t)
Ok..thanx.. i got 4 people assisting me so i should be done in a day... i got the OBD2 stuff covered because i knew that was going to be an issue
Old Apr 17, 2008 | 09:09 PM
PACT man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da itr-t &raquo;</TD></TR><TR><TD CLASS="quote">Ive done quite a few r&rs on integras. Mostly da's but i've done 2 dc2s. never kept too much track of time, but to take one out (added everything goes smoothly) i'd say noo more than 4.5 hours. So figure to replace 5.5 max. Thats with taking your time. Three days would be more then plenty, excluding the fact that your putting an obd2 motor in an obd1 car..</TD></TR></TABLE>
I know DA's take longer(Used to have a DA that I did an auto to manual and LS to B20 swap at the same time and that only took 2 days[about 9hours total, having to swap a bunch over]), but 4.5 for a DC just to pull it out? 2 hours is a generous time just to pull it out. I can pull out the tranny and throw another one in with the car only on jackstands in an hour and a half.
Old Apr 17, 2008 | 09:22 PM
2ndchirp's Avatar
Default Re: (PACT man)
the DC has alot of room to work with so ill give it no more than 2days... its only the engine not trans.... i've done auto to manual swap on a prelude and it was a headache at first.... but the engine came out inless than an hour wittt power tools and a forklift
Old Apr 17, 2008 | 09:24 PM
PACT man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndchirp &raquo;</TD></TR><TR><TD CLASS="quote">the DC has alot of room to work with so ill give it no more than 2days... its only the engine not trans.... i've done auto to manual swap on a prelude and it was a headache at first.... but the engine came out inless than an hour wittt power tools and a forklift</TD></TR></TABLE>
It's easiest and quickest to pull both out at the same time. But anyways, it should not take long at all since you have some prior motor removal experience.
Old Apr 18, 2008 | 10:11 AM
da itr-t's Avatar
Note i said taking your time, and no more than 4.5. Im sure if i, or anybody were in a huge rush, they could get it pulled in under 2/2.5. But if you have 3 days, and you want to make sure your doing it all correct & clean. I'd say 8-9 hours total is a good estimate thats quoted working alone and im part perfectionist lol. good luck!
wowy978
Engine Management and Tuning
Oct 7, 2008 11:05 AM
jr408
Feb 23, 2008 08:25 AM
blackcrx16
Mar 7, 2007 08:01 AM
T_bones
Jan 23, 2006 11:17 PM
Steve-o
Oct 8, 2005 09:12 PM
