Doing an LS/VTEC
Old Apr 19, 2008 | 01:37 PM
vegassinsation's Avatar
Default DOING AN LS VTEC
I WANT TO MAKE MY LS VTEC WHAT WOULD BE BETTER B16 HEAD,OR A GSR HEAD OR TYPE R IM ALSO PLANNING ON PUTTING TYPE R PISTONS ANY SUGGESTION
Modified by vegassinsation at 2:50 PM 4/19/2008
Modified by vegassinsation at 2:52 PM 4/19/2008
Old Apr 19, 2008 | 01:48 PM
Schister66's Avatar
Man U FTW
My suggestions:
1. Spell "LS/VTEC" correctly...no "H"
2. Turn off the CAPS LOCK button
3. Use punctuation
4. Search the forums...this has been covered several times recently
Old Apr 19, 2008 | 02:54 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (Schister66)
If you can't find your answers in here, you didn't read anything
https://honda-tech.com/zerothread?id=1676914
Old Apr 19, 2008 | 04:37 PM
HONDRETTI's Avatar
Default Re: (SlammedDC2)
a what?
Old Apr 19, 2008 | 04:53 PM
I AM WEASEL's Avatar
Default Re: DOING AN LS VTEC (vegassinsation)
Determining what head is better is a hard thing to do because it depends on what your planning on doing with the motor and your goals. It also depends on what parts you are gong to be using as some things are different between the heads I.E the intake manifold. Another thing to consider is that the b16 and the itr heads are pretty similar (casting wise) - the itr head has been mildly posished, has slightly more aggressive cams, and has better valvetrain when compared to the b16. Also remember that a gsr head will increase your compression due to the smaller compression chamber volume.
Be sure to check out this thread How to build a "reliable" lsvtec/b20vtec as it is a guide for building ls/b20 vtec motors.
Old Apr 20, 2008 | 08:40 AM
jhammond_82's Avatar
Reject Papi
Default Re: DOING AN LS VTEC (-DC4-)
umm.... search maybe?
mike integra
Sep 28, 2008 05:26 AM
shawty123
May 12, 2007 05:12 PM
99lsvtecauto
Nov 16, 2003 03:09 PM
coldfiremx
Mar 11, 2003 04:36 PM
ChrisAnF1892
Feb 27, 2003 12:36 PM
