CKF help.
Old Apr 18, 2008 | 07:01 PM
HondaKid_1's Avatar
Default CKF help.
ok guys here is one for yea. my friend and me were switching cam gears. my friend dropped a cam key down the timing belt cover.......he said it wont hurt anything....WRONG.lol well it broke a tooth off the CKF and then i started to throw a code. well i switched to 0bd1 for my tuned ecu. so it did not matter much to me. well now smog if coming up. iI found a write up on how to unplug my CKF and splice it down by the ecu to read off the CFP. well i did that and went to smog. threw a code 71 fail. not happy it keeps throwing it when i hold it at 2500 RPMs for 30 sec. do i need to replace the CKF now? or is there any other way to get around it? thanks for taking the time to read this hope someone can help.
Modified by HondaKid_1 at 8:55 PM 4/18/2008
Old Apr 19, 2008 | 11:31 AM
HondaKid_1's Avatar
Default Re: CKF help. (HondaKid_1)
No help at all?
Old Apr 19, 2008 | 06:24 PM
stevieteg's Avatar
Is this the page you used to bypass it?
http://technet.ff-squad.com/ckftrick.htm
If that doesn't work I guess you'll need to replace the CKF.
Old Apr 20, 2008 | 12:46 AM
HondaKid_1's Avatar
Default Re: CKF help. (stevieteg)
yes,yes it is.lol still a cel when i hold it at 2500 for 30sec for smog. says i have a missfire in cylinder 1. i changed plugs cap rotor wires and dizzy still same code cmoes on at the same time think it could be the ecu?
Old Apr 21, 2008 | 08:02 AM
stevieteg's Avatar
I seriously doubt its the ecu. I haven't ever tried to to this trick, but I would double check your work. What is code 71? Does it just throw a cel @2500 in neutral, or when your driving too?
Old Apr 23, 2008 | 09:43 AM
HondaKid_1's Avatar
just in neutral at 2500. i just took the long way around it and changed the ckf gear and sensor. passed with flying colors. yay another two years i dont have to worry.lol
DTR1
Aug 4, 2013 04:53 PM
blasterman87
22
Sep 25, 2009 07:50 AM
d16y8EL
Jun 6, 2005 09:02 PM
Nanoboy
Oct 7, 2002 02:55 PM
