standard to Automatic
Old Apr 17, 2008 | 08:59 PM
hammergunner's Avatar
Default standard to Automatic
I have a 92 RS integra, and need to know what it would take to switch the car to automatic
Ive got the whole automatic motor swap
Motor,Trans,Ecu, Automatic Shifter,Auto Radiator
And would things like the Clutch Sensor and standard Car Wiring Harness get in the way also?
Old Apr 17, 2008 | 09:05 PM
clean3two3's Avatar
Default Re: standard to Automatic (hammergunner)
another stick DA gone down the drain. i was wondering whats your motive for this change?
Old Apr 17, 2008 | 09:06 PM
PACT man's Avatar
Buy an auto car. You would need the auto ECU, the under dash and engine wiring harness, the brake switch is probably different to send the signal to the shifter. It's just too much to do with the auto ECU and wiring things
Old Apr 17, 2008 | 09:10 PM
My homies wife had to sell here accord, and wants another automatic, we found her the 92 integra, but she wants it automatic
Old Apr 17, 2008 | 09:16 PM
what?, i've changed a standard civic motor to automatic
the motors are the same, and IF you read the frist post i have EVERTHING, Motor with trans and harness, plus ECU, and Automatic sifter
Old Apr 17, 2008 | 09:18 PM
Default Re: (hammergunner)
and whats this brake thing, ive seen a automatic shifter, its just 1 cable to the tranny
and a stupid locking pistion on the shifter(which i always remove)
Old Apr 17, 2008 | 09:33 PM
PACT man's Avatar
The shifter has a couple of plugs on it. And he auto ECU things depend on the year. A Civic may not have the ECU, I have seen a DC converted to auto from manual. I did a auto to manual swap in my old DA though and there is the auto tranny ECU and associated under dash wiring.
Old Apr 17, 2008 | 09:42 PM
so that means its not going to work, unless i take the whole underdash harness from another automatic integra?
Old Apr 17, 2008 | 09:55 PM
PACT man's Avatar
I've never actually tried obviously, but I'm pretty positive just from going the other way and seeing the things that I pulled out and were they went and connected to that its definately not worth it.
Old Apr 17, 2008 | 10:17 PM
Default Re: (PACT man)
well ive done the Standard to Auto conversion on a standard motor to replace the blown auto one
add all i had to do was replace the trans,headers, and intake manafold and driverside motor mount with those on the automatic motor
so im sure its not any differant to swap them backwards, all id have to do is
cut a hole for the automatic shift linkage
Old Apr 18, 2008 | 05:30 AM
teg_73's Avatar
Dont do it!!! If you want an automatic car just buy one that comes auto. I went through the headache of switching my 92 DA from auto to manual. The shop i took it to messed up so bad that i spent close to 5 grand on top of the swap just to fix what they screwed up on. Just trust me man its not worth the headache!!!!!!!
Old Apr 19, 2008 | 07:31 PM
well im not doing the auto to manual, im doing from manual to automatic, and i've done ton's of swaps on manual civics, and integra's
i can't see why you can do the same with an automatic motor, all the real difference is the trans shifts for ya
i've got everything i need for the swap, and i can do custom work if needed for the shif linkage, and "IF" i have to, i'll pull the harness from an automatic at the junkyard...THERES TONS THERE
Modified by hammergunner at 8:45 PM 4/19/2008
Old Apr 19, 2008 | 10:28 PM
Blahblah718293's Avatar
i say just look for another car, manuals are SO much more in demand youll find one that COMES auto for cheaper.
Old Apr 20, 2008 | 05:39 PM
I need to know if its "possible" to just do a few mods to the car to make it automatic.
other then bypassing the clutch sensor, and custom cutting and welding the shifter area
i see no reason why this wont work. and i can find a way to bypass a brake pedal sensor. (this is what they do for remote start)
so if anyone has any experience trying this, tell me. Sll others who say buy another car, don't bother posting!!!!!
Modified by hammergunner at 6:46 PM 4/20/2008
Old Apr 20, 2008 | 05:47 PM
and if no one can give me help, i'll just do it on my own, and "if" i get it running, i will have to slap someone with a piston.
Old Apr 20, 2008 | 06:21 PM
theres no doubt in my mind youll be able to do it. it propably wont be much harder than an auto to manual swap. but will it be worth it? i doubt it seeing as how you can get one with auto for less money.
Old Apr 20, 2008 | 06:26 PM
monkeyfr8's Avatar
There is no metal fabrication needed the, auto shifter consol bolts into the stock location and the trans mounts are the same on the da9 not the same for a dc2, Make sure you ecu is from a 92 93 however
Old Apr 27, 2008 | 06:16 PM
Thanks Monkeyfr8
And for everyone who thinks an automatic car is cheaper, "what the f#@$ are you smoking", an automatic car is considered a "Luxury car" since you don't have to shift the gears.
you can find an slandered 95 Integra around here for $4500, and the automatic model for more then $6000(this was taken from a used acura car dealership)
Modified by hammergunner at 7:46 PM 4/27/2008
Old Apr 27, 2008 | 08:31 PM
caseyliffick's Avatar
yeah, i looked at about 1500 for an automatic to manual. I'd say atleast that for a swap the other way. You'd be much better off selling it, or teaching the woman to drive a stick lol
SPITVENOM67
Apr 5, 2012 06:10 AM
ZAKU
Jun 30, 2008 06:50 PM
zephon96
Apr 3, 2005 03:05 PM
T-dog
Sep 19, 2002 09:40 PM
