baffle needed for LS/VTEC block?
Old Apr 14, 2008 | 10:45 PM
b20quang's Avatar
Default baffle needed?
im in the works of building a lsvtec. DO I need an oil pan baffle or is that only for gsr and type-r blocks?
Old Apr 15, 2008 | 05:12 PM
b20quang's Avatar
Default Re: baffle needed? (b20quang)
any1
Old Apr 17, 2008 | 01:32 AM
b20quang's Avatar
Old Apr 18, 2008 | 10:25 AM
b20quang's Avatar
any1
Old Apr 18, 2008 | 12:32 PM
g2daturbo's Avatar
BAFFLE??? are you talking about the windage tray on the bottom of block??what oil pump and pan are you running
Old Apr 18, 2008 | 10:24 PM
b20quang's Avatar
Default Re: baffle needed? (g2daturbo)
im using an ls oil pan with a type r oil and water pump. baffle im refering to is this
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Apr 18, 2008 | 11:10 PM
Targa4Life's Avatar
That is a windage tray and yes you need one. However your engine should already have one...... Every B-series has one stock however the GSR's and Type-R's have a different one from the LS.
Old Apr 19, 2008 | 01:57 PM
b20quang's Avatar
Default Re: baffle needed? (Targa4Life)
i dont have one bc im buying everything and putting it together. im not adding a vtec head to my exisiting block. im running an ls oil pan, does that mean i need a windage tray for an ls
Old Apr 23, 2008 | 11:06 PM
Targa4Life's Avatar
yes!!!!!
2low93
May 26, 2012 10:44 AM
KMk51188
Dec 15, 2006 02:38 AM
sasinorm01
Aug 5, 2004 01:10 AM
Ad4mGSR
May 2, 2004 02:52 PM
