throttle cable
Old Jun 22, 2008 | 06:57 PM
r1chst3r's Avatar
Default throttle cable
ok well i just got done with my gsr swap on my 94 integra and when i tried to connect the throttle cable seems like its to long. oh and by the way the engine i had before was an ls. is there anyway to make it shorter or im better off getting a new throttle cable?
Old Jun 22, 2008 | 07:38 PM
r1chst3r's Avatar
Default Re: throttle cable (r1chst3r)
Come on now i know there is somebody who has done a gsr swap on a 94 teggy
Old Jun 22, 2008 | 07:39 PM
vtecb18c's Avatar
im using an ls throttle cable on my gsr..it does stick up a little bit but it doesnt effect it in anyway
Old Jun 22, 2008 | 07:42 PM
r1chst3r's Avatar
Default Re: throttle cable (vtecb18c)
hmmm i see well i tried to put it on and when i step on the gas pedal it has alot of slack and does not turn the throttle i mean it has alot of slack is there anyway to fix that?
Old Jun 22, 2008 | 07:46 PM
Brice.Hayden's Avatar
we used an EG one on a gsr swap and it worked fine. Just try to tighten it at the anchor point on the Intake manifold, that worked for us
Old Jun 22, 2008 | 07:50 PM
r1chst3r's Avatar
Default Re: throttle cable (Brice.Hayden)
i see what ur saying its not the plastic cover that is long but the wire cable. Its right on the intake manifold but just the wire cable that seems to long and i dont know why when i got the car it had that same problem with the ls it seemed a little but to long but now with the gsr its just crazy long lol
Old Jun 22, 2008 | 07:54 PM
vtecb18c's Avatar
yea if theres that much slack you need a new cable.like what was said earlier a 92-95 civic cable will work fine and a gsr obviously
Old Jun 22, 2008 | 07:57 PM
r1chst3r's Avatar
Ok well thanks guys i guess i have to hit the junk yard tomorrow and get one so i can get the car running and it was a nice of experience on my first swap ever i had some help but they wanted me to learn so i had to do the work lol iight like i said thanks alot.
Old Jun 22, 2008 | 08:18 PM
shawnxme's Avatar
Are you using a GSR or LS throttle cable? If you're not using a GSR throttle cable just go to Acura and buy it.. it's only like $25.. the LS is probably too long..
I used to use a GSR throttle cable on my LS engine, made a huge difference after I got the right one for my car.. LS.
Old Jun 22, 2008 | 09:13 PM
r1chst3r's Avatar
Default Re: throttle cable (shawnxme)
im using a ls the same one that the car came with i guess ill just go to honda/acura dealer ship tomorrow and get one well thnx guys
Old Jun 22, 2008 | 09:18 PM
619GSR's Avatar
You will need the GSR throttle cable as well as a GSR throttle body pulley depending on if you are using the ls TB or the GSR TB.
Old Jun 22, 2008 | 09:27 PM
r1chst3r's Avatar
Default Re: (619GSR)
the engine has the GSR TB so that means i need the gsr Throttle cable
Old Jun 22, 2008 | 10:15 PM
619GSR's Avatar
ya just get the cable and your all set, hey you wouldn't happen to still have the ls throttle body would you. I put the type-R throttle cable on my skunk2 intake manifold and I need a ls TB pulley.
Old Jun 22, 2008 | 10:17 PM
r1chst3r's Avatar
yeah i still have it i was going to give it to my brother which he is going with the b20 swap on his civic and he needed one bc of his hood but ended up getting an obd2 since he has a 97 and mine was from a 94 ls
Old Jun 22, 2008 | 10:19 PM
r1chst3r's Avatar
Default Re: (r1chst3r)
wait i mean the intake manifold but yeah i still have the TB
Old Jun 23, 2008 | 03:14 PM
619GSR's Avatar
how much you want for the TB?
g0tgot
Oct 11, 2008 07:50 AM
ateggy1
Mar 17, 2008 09:27 PM
123Four
Sep 12, 2007 03:08 PM
Ekizzle
Dec 27, 2004 11:21 AM
mrbsponge
11
Feb 3, 2004 04:03 PM
